Old May 16, 2012, 09:34 AM
tincanrider is offline
Find More Posts by tincanrider
United States, CA, Tehachapi
Joined Aug 2009
Prop Shafts
I am building a DUMAS 1/20 PT twin motors this time, (two SS-1 mounted mid-ship) with the prop shaft angle this places the motors high in the hull just under the deck, do not want to shorten the shafts, do not recall seeing any builds that have used two universals on each shaft to lower the center of gravity and get motors lower in hull, any one tried this with out any problems. I am familar with shaft aliment-motor to shaft from real world jobs +/- .002 run out.
Thanks, Keith
tincanrider is offline Find More Posts by tincanrider
Old May 16, 2012, 10:10 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
In my 1:20 PT, I use intermediate shafts with half dogbones on each end (equivalent to two u-joints)... the motors sit low and far forward, and she runs smoothly.
http://matthewsmodelmarine.wordpress...e-expendables/
I'll post pics of the actual shaft soon as I find them...
patmat2350 is offline Find More Posts by patmat2350
Old May 16, 2012, 10:11 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
See http://www.rcgroups.com/forums/showthread.php?t=1604929
Discussion Gemfan 5x3x3s on 2mm prop shafts require aftermarket prop adapters. Link anyone? daign Multirotor Talk 0 Mar 03, 2012 11:17 PM
Found Collet Prop Adapter for 5mm Shafts Khosravi Aircraft - Electric - Power Systems (FS/W) 3 Mar 01, 2012 04:59 PM
Wanted APC prop sleeves,shaft adapters amapmfg Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 22, 2012 11:28 PM
Sold NIB Graupner Prop Shaft,and Props unclecrash Boats (FS/W) 0 Feb 07, 2012 05:58 PM
Wanted Prop Savers: 2mm Shaft & 4mm hole PROP P.M.S Aircraft - General - Miscellaneous (FS/W) 0 Dec 23, 2011 01:33 AM
