Old Feb 23, 2012, 01:39 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Build Log
Sunset Models F15 Eagle Build Thread
Wanted to start build thread on the Sunset Models F15
One of the reasons I like this model is because of Buzz has worked hard to keep it simple, it's ability to scale as I go along and the price ...it's 429.00 usd for the short kit and 650.00 usd for the full kit before shipping.
It's a nice sized model but it's wing load CAN be kept fairly low, Buzz has some different powering options from 1x120mm to 2x120mm and even 2x 90mm fans if you got a couple laying around begging to be placed in a model.
I'm going to maiden with the CS 120mm 4 blade fan and SUPPO motor with Turnigy\HobbyWing esc.
After maiden, land it nice after 3 good flights and get to scaling, drop tanks, paint, lights etc...just my tradition...Don't like to scale a jet I'm scared of flying.
Specs:
- 86L x
- 57ws
- 14 16lbs AUW
Parts list so far
Gear
- Nose and mains
(link)
- Wheels (nose (link))
- PZ 1509 etracts with metal trunnions (link)
Servos
- HK High torque, High volt servos (link) for tailerons
- Corona (link) for rudder
Power system
- CS 120 mm 12 blade (link)
- Motor (link)
- ESC (link)
RX
- RX With RSSI (link)
- Dual BEC (link)
For twin 90mm 8s
- CS 12blad 90mm (link)
- Turnigy 3126 (link)
- ESC (link)
Going to do a single CS 120 fan and then paint and scale it out with AB lights and drop tanks etc. Then fly it with twin CS 90mm 12 blades fans Buzz from Sunset Models is making ducting for.
I will split the build log into aircraft sections NOSE, FUSE, WINGS starting with the nose..
NOSE:
erh7771 is online now Find More Posts by erh7771
Old Mar 02, 2012, 09:50 PM
buzz1040 is offline
Find More Posts by buzz1040
buzz1040's Avatar
United States, FL, Ocala
Joined Feb 2012
Glad to see this started.
buzz1040 is offline Find More Posts by buzz1040
Old Mar 03, 2012, 06:58 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Nice choice. Good luck with the build and maiden.
One question, what retracts are those?
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Mar 04, 2012, 02:19 AM
Joined Nov 2005
Cheers,
Eric B.
PZ 514s but with metal trunions.
I've gone way over the weight with the smaller ones with the plastic trunnions in the past.
Old Mar 04, 2012, 09:17 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Thanks for the info.
Who offers the metal trunions?
Eric B.
Old Mar 04, 2012, 09:36 AM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
You are not worried about those retracts at 16lb AUW? Is your field paved?
scatsob is offline Find More Posts by scatsob
Old Mar 04, 2012, 01:35 PM
Joined Nov 2005
Club field is fairly bumpy I'm more concerned about the mount than the pz etract, gonna do a strut back stop to help with giving the strut mount some help.
Impressed with the PZ etracts after they fixed their transistor issues. Been using the 2.5kg on near 10lbs DC 10 for 2yrs and many flap less landings with little issues to speak of.
Old Mar 12, 2012, 10:55 AM
Joined Nov 2005
More pics,
Got the Fuse this weekend and starting on getting the formers in.
I was expecting to get the fan this weekend but snail mail has it bottled up somewhere in God knows where.
Prolly will have it this week so I'll be able to balance it and get the exhaust ducting fitted to it.
Old Mar 16, 2012, 10:49 AM
Joined Nov 2005
More progress
Balanced another fan for maiden. The CS 120 4 blade fan needs a long 6mm shaft and I have to install it later but for now the haoye 127mm with "special" motor will do.
More pics
Old Mar 16, 2012, 01:17 PM
rcshirt is offline
Find More Posts by rcshirt
miniture aircraft pilot
rcshirt's Avatar
United States, FL, Tampa
Joined Oct 2007
i'm onboard,
there's a guy here locally that had been trying to sell one, but i gut got 3 other planes(jets) so i passed on it. Nice large f-15.. turbine size
rcshirt is offline Find More Posts by rcshirt
Old Mar 19, 2012, 10:52 AM
Joined Nov 2005
Some mods for variety...
I thought over the weekend I would love to test the theory of having intakes feeding air into an installed fan vs an open air intake with intake lip installed like a good amount of Byron fans do.
I thought the motor mount mod would be simple and easy and it was, so this mount would allow for open air intake with shroud lip AND intake with some Fliteskin or I'll just carve some foam and make my own intake tube.
Coming along...
Seems like the in air time for this model is very short, I've spend a total of 5hrs so far...
I think the wings might be the hard part, we'll see
Old Jun 29, 2012, 07:06 PM
Joined Nov 2005
Getting back to building for fall fly ins
Getting back to build after some time off experimenting with electric smoke system and some other 120mm+ fans....things are going great hope to have something before year end is up.
Got some work done on taileron rods and mains...fan install comes next
Old Jun 29, 2012, 07:26 PM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Nice job!
Gamalier is offline Find More Posts by Gamalier
Old Jul 02, 2012, 09:46 PM
Joined Nov 2005
Spent all day Sunday assembling and balancing fans
....here are some numbers
Haoye with 670kv 5045 big foot motor from Hobby partz
104 amps
13lbs thrust
35volts
T600 880kv motor and ETurbax rotor
16lbs 10oz
140 amps
41 volts
CS 12blade 120
14.5lbs thrust
95 amps
44 volts
I'm going to use the FighterCat RC 16s esc with the CS 12 blade 120mm if the mods to the 120 work out and the rotor assembly can take a beating...
I'll be putting the esc in front of the fan about an inch or two so I'll be able to put the batteries in multiple locations for balancing...
Thing screams for twin 90s
Old Jul 02, 2012, 09:47 PM
Joined Nov 2005
Originally Posted by Gamalier View Post
Nice job!
Thx, can't wait to start painting this thing
Build Log 300% Guillows Build & Show F15 Eagle Conversion Electriflier Scale Kit/Scratch Built 184 Nov 11, 2011 02:58 PM
Sold Sunset Models F-15 "Sport Eagle" Jet Jetnfast Aircraft - Fuel - Jets (FS/W) 5 Oct 07, 2011 05:43 PM
Build Log Sunset Models F-15 Sport Eagle bill34207 Electric Ducted Fan Jet Talk 57 Jun 14, 2009 06:37 PM
Discussion 3d Foamy's F15 Eagle Build Help ianm Pusher Prop Jet Models 1 Dec 30, 2005 08:46 PM
