Old Feb 02, 2012, 09:09 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
Help!
shorten pentium motor wires?
don , i am having a space issue w/ the wicked wemo combo in my j power mini f9f . is it ok to shorten the output wires on the esc (pentium 30) . i wont shorten the motor wires per your instructions.
thanks, chuck.
chas650r is offline Find More Posts by chas650r
Old Feb 02, 2012, 03:40 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Not a problem on the ESC side.
Don
The Don is online now Find More Posts by The Don
Old Feb 02, 2012, 04:07 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
Don
thanks.
Old Feb 04, 2012, 03:18 PM
soopertrucker is offline
Find More Posts by soopertrucker
soopertrucker's Avatar
United States, TN, White House
Joined Oct 2011
Just curious why you should'nt shorten the motor wires.
soopertrucker is offline Find More Posts by soopertrucker
Old Feb 04, 2012, 03:58 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The motor wires are just extensions of the winding wires inside the motor. So if you shorten them them you no longer have nice soldered tinned ends. You will have many strands of insulated/enamel coated wire which you cannot solder to. You would need to then strip the enamel off of each of the three motor wires, but each motor wire is made up of about 10-12 smaller substrands of thinner wire so you would have to strip ~30-36 wires and then retin them for soldering. I have done it once to see if I could do it and it is very easy to break the smaller strands off or not get them stripped off properly so instead of all 12 wires carrying the amp load in one phase, say only 8 carry the load so a phase can burn out.
Old Feb 05, 2012, 12:07 AM
Joined Oct 2011
Gotcha, thanks for the explanation Don.
Old Aug 18, 2013, 01:28 AM
losthorizonmba is offline
Find More Posts by losthorizonmba
losthorizonmba's Avatar
India, SK, Gangtok
Joined Feb 2013
Thanks for the heads up
Thanks for the explanation Don.
losthorizonmba is offline Find More Posts by losthorizonmba
Question Is it O.K. to shorten the Lipo wires? papabearflying Electric Plane Talk 7 Aug 15, 2011 12:34 PM
Discussion I actually need to SHORTEN my ESC wires Staggerflyer Castle Creations 2 Apr 25, 2011 05:55 PM
Discussion Shorten motor wires Petefoss Castle Creations 1 Jan 12, 2007 06:11 PM
Discussion Can I shorten Kontroniks ESC battery, motor, or receiver wires? kenmalecki Electric Heli Talk 2 Jun 11, 2006 09:18 PM
Discussion Shorten the wires to the motor? Old Fart Castle Creations 2 Apr 17, 2006 01:50 PM
