Old Sep 19, 2013, 07:23 AM
Thermicdude is offline
Find More Posts by Thermicdude
Still hackin'
Thermicdude's Avatar
Port Elizabeth, South Africa
Joined Nov 2005
Build Log
X-UAV Talon build thread
My Talon has finally arrived, after a week of hair pulling frustration with customs I've been looking for a replacement to my worn out Skywalker and fell in love with the looks of this.
I'm not the fastest, um, assembler, but I plan on getting this one in the air as soon as. I have the week off next week so will try to get as much done as possible.
Nice sturdy box...
Thermicdude is offline Find More Posts by Thermicdude
Old Sep 19, 2013, 07:56 AM
Still hackin'
Joined Nov 2005
Best packing on anything I've received from BevRC
Old Sep 19, 2013, 08:14 AM
Still hackin'
Joined Nov 2005
Now that I've pulled everything out, I'm impressed. The molding is clean and that inspires me with confidence that it's going to slot together perfectly. Includes a spare clear dome and the usual bag'o'bits which I'll get into later. This is going to be one purdy aerie.
More to follow next week...
Old Sep 19, 2013, 11:20 AM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
pffft you only ordered the one ?
Blackrat is offline Find More Posts by Blackrat
Old Sep 19, 2013, 11:30 AM
Still hackin'
Joined Nov 2005
You prepared to come down off your quadrotor high horse? If it goes well we can get a couple more...
Old Sep 25, 2013, 08:32 AM
Still hackin'
Joined Nov 2005
Some more pics - carbon rod for stiffness and a perfect fit for the BEVRC ES08MA servos. Happy with that
The molded in centre hinges (not top) are also far better than that of the Skywalker, both on the ruddervators and the ailerons. I will make a call on them later.
Old Sep 25, 2013, 08:48 AM
Still hackin'
Joined Nov 2005
The wing is stiff and smooth, good molding and the same hinges as the ruddervators. The joiner tubes go OVER the ones in the wing.
Old Sep 25, 2013, 09:01 AM
Still hackin'
Joined Nov 2005
The backbone of the Talon is made up of 6 laser-cut ply components that slot together, a real triumph of CNC production. The wing joiner is a snug but perfect fit.
The whole assembly slides neatly into place in the molded sides.
Old Sep 25, 2013, 09:09 AM
Still hackin'
Joined Nov 2005
The fuselage halves have pre-installed carbon rod longerons to beef up the front end.
It has an integral centreline wheel and small ourunners - look draggy to me but will install, I can always clip them off.
There also a great accessory pack, much better quality then the Skywalker etc.
Old Sep 25, 2013, 09:41 AM
Still hackin'
Joined Nov 2005
Comes with one spare dome - nice and clear. I may paint the white EPO matt black inside to prevent reflections. Took a few pics through the dome.
Old Sep 25, 2013, 11:32 AM
isbeorn is offline
Find More Posts by isbeorn
Radioactive ebola carrots
Sweden, Skåne County
Joined Mar 2012
Subscribed
I'm also looking to replace my Skywalker. With something that's more portable and can still fit an awful lot of equipment. This looks promising.
isbeorn is offline Find More Posts by isbeorn
Old Sep 29, 2013, 01:31 PM
Still hackin'
Joined Nov 2005
After a bit of debate I pulled an E-Flite 32 out of a retired (very tired!) plane. It will probably be overkill but should provide plenty of go on 4S - said Zippy 8000mAh 4S pack is swallowed up in the fuz. There's probably room for 3 abreast.
Old Sep 29, 2013, 04:35 PM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Wow a 32 sized motor! Here I was thinking about just going with a '15' sized motor vs the 25.
typicalaimster is offline Find More Posts by typicalaimster
Old Sep 30, 2013, 06:49 AM
Still hackin'
Joined Nov 2005
"Use what you have"
I had the 15 on the Skywalker but it only happily turns a 9x7 on 4S and I really want a big pitchy prop - a 12 or 13" - cruise speed!!!
Old Sep 30, 2013, 04:19 PM
Joined Jan 2005
Originally Posted by Thermicdude View Post
"Use what you have"
I might have to follow your lead on this. I have a G32/600 laying around and RCTimer still hasn't sent my motor. I ran eCalc on the G32 and things look a little to good. That was swinging a 14" prop!
News Talon UAV from FPV Model Matt Gunn FPV Aircraft 3112 Yesterday 11:56 PM
Build Log Talon Experimental EDF plane building in progress thread ISNJH Foamies (Scratchbuilt) 4 Dec 03, 2006 02:12 PM
Build Log T-38 Talon build thread Jeff Charlot Pusher Prop Jet Models 51 Sep 21, 2006 12:54 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
