Old May 19, 2014, 06:59 PM
dro56595@bigpo's Avatar
Australia, NSW, Williamtown RAAF
Joined Aug 2008
Looked good to me. The only yaw I saw was due to the strengthening crosswind above the tree line.
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old May 20, 2014, 03:48 AM
United Kingdom, England, Somset
Joined Aug 2013
thanks for the kind words guys
first .... the powerlines 3/4 mile away , hedge i can live with lol the field is bigger then it looks in the video
i have no rudder on this plane , and in the turns i may be at 1/4 to 1/3 throttle just to show how slow this plane can fly
thanks
Evopower is online now Find More Posts by Evopower
Old May 20, 2014, 08:12 AM
Australia, VIC, Melbourne
Joined Nov 2006
hehe, hard to use some Rudder then.....
Videos normally make things look faster than they are, but yours looked to land very slow. (even allowing for that 'opposite' visual speed error). Maybe some head wind..... or it is very light?? (or both).
The power lines looked within my flying range! LOL
I think I fly about a 300m radius typically (with 90mm sized jets). (600m "box", 150m height max I would think) (0.5mile approx)
PeterVRC is offline Find More Posts by PeterVRC
Latest blog entry: FPV Cameras & fixed or pan/tilt
Old May 20, 2014, 08:43 AM
Joined Aug 2013
when i take off you see the tree line in the background , the power lines are the same distance again from the tree line (so maybe 1/2 to 3/4 mile (no one hit them yet lol)
on that day the wind was 3-5 mph , flying weight with lipo just under 3kg
very stable and nice model to fly (ive only been flying 9 months) so i appreciate your input
Old May 20, 2014, 04:43 PM
Waterford, ON, Canada
Joined Nov 2007
Only been flying for 9 months! Well, that explains it then- beginners luck!
Just kidding- you fly very well.
Tom
pogoed is offline Find More Posts by pogoed
Old May 20, 2014, 05:49 PM
Fly it like you're in it
microlyn's Avatar
Canada, ON, London
Joined Nov 2012
Evo, if you were to build another one, would you make any changes, ie... retracts, flaps, rudder power system, finish...?
Reason I'm asking is, I'm building one next and I may go heavier finish/trim 8s jetfan power or light simple Midi Evo 6s
microlyn is offline Find More Posts by microlyn
Latest blog entry: painting/finishing dynam 109
Old May 20, 2014, 06:15 PM
Joined Nov 2007
I don't know if you saw this, but mine is "full-house" and glassed- weighs 8.5 lbs., 6 cell HET 1200 w power. See what you think...
Tom
7 23 13 Fury (4 min 12 sec)
Old May 20, 2014, 06:53 PM
Joined Nov 2006
That looks really nice too!
Just 1200 Watts for that AUW?? It did look a little bit slow, but still scale 'cruise' speeds.
I guess my Me-262 is much the same specs, 3.8Kg (8lb?) but 1800W - though flies at 50% throttle for 'cruise'.... quite a similar wing/jet design really.
Old May 21, 2014, 04:54 AM
microlyn's Avatar
Canada, ON, London
Joined Nov 2012
Looks great Pogoed!
How is ROG take off on shorter grass?
Old May 21, 2014, 04:59 PM
Joined Nov 2007
I must say it flew heavy at that weight and soon removed the retracts (about 12 oz.)- that grass is just impossible (but good on bare feet!) I can't comment on the ROG from a better surface, consequently. If you are contemplating one around this weight, I think a 15 to 1800 watt 6 or 7 cell system might work well- I plan on re-powering at some point with an Evo or Jetfan.
Tom
Old May 22, 2014, 07:56 AM
Joined Aug 2013
hi bud
i would add a rudder (may still do that)
power wise is fine , i fly on a 4000 6s lipo which is as far forward as i can for the CG , may be on 8s you might have to add some weight to the rear.
retracts are holding up fine for 30 from hobbyking
just make sure you put carbon rod in the wings and beef up the retract mounts
dont need flaps as it comes in slow for landing
Old May 22, 2014, 04:48 PM
microlyn's Avatar
Canada, ON, London
Joined Nov 2012
Thanks Evo,
Those MiG struts look cool
Great job!
Old May 22, 2014, 05:46 PM
Joined Nov 2006
MiG on a Sabre!!!! Sacrilege!
LOL.
Old May 24, 2014, 12:37 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
From my experience with FF kits, those junk plastic wheels will last one landing, at best.
Herb is offline Find More Posts by Herb
Old May 24, 2014, 09:42 PM
Joined Nov 2006
You are almost right Herb.....
I thought the same.
But my F-4 Phantom nose wheels are lasting fine - though one did 'grind away' the tire when the lock nut somehow did itself up more and jammed one wheel!!
But other than that it is lasting very well - all use is on Asphalt (road) runway.
Mind you, on my F-22 (FlyFly of course) when it had 'ground handling issues' and veered off course strongly, at high speed on the runway (road), those lateral forces were too much and the hub 'exploded'.
But as long as they operate 'normally', as per a real plane would, they will be fine. (eg normal running, landings etc).
Maybe hard to assure that is always the case! hehe
Build Log Jet Hangar Hobbies (JHH) F-86 Sabre Build Ken Lapointe Electric Ducted Fan Jet Talk 1292 Jul 06, 2014 06:05 PM
Yippee! Cool Fly Fly Hobby F-86 Sabre !!!!! ARCHER7153 Foamy EDFs 571 Sep 12, 2010 02:34 PM
Discussion Fly Fly Hobby F-86 Sabre dbatey Foamy EDFs 4 Nov 05, 2007 08:57 AM
Discussion Fly Fly Hobby F-86 Sabre dbatey Australia 0 Nov 04, 2007 10:04 AM
How hard is it to fly an f-86 Sabre? Starguard Parkflyers 4 May 03, 2004 05:23 AM
