Old Yesterday, 02:01 PM
wrathofkhan's Avatar
Los Angeles, California
Joined Jun 2006
Help!
How can I reduce voltage - from 5V to 4V?
Hello
Straight up, I do not know much about electronics, beside some simple soldering
for my project, I am using a Castle ESC/10, where the BEC output is 5.0V (at the lowest setting). I need to drop it down to 4volts, otherwise the tiny servos I am using will burn up since they are rated at 4.2V
How can I do the voltage drop? Advice, link would be very much appreciated. Thank you in advance ... Khan
wrathofkhan is offline Find More Posts by wrathofkhan
Old Yesterday, 02:37 PM
Joined Nov 2012
use diode, but check the max current first
there are some with 1A that i used, by connecting few in parallel you may use more current, they MUST be the same diode
use only 80% of the max current of your diode
goly is offline Find More Posts by goly
Old Yesterday, 04:01 PM
Joined Jun 2006
thank you for your post ! do you have any suggestion on which diode to buy, i have no clue what so ever
i was planning on using it on a tiny servo: Spektrum H20240L 2.9 Gram Linear Long Throw Cyclic Servo (130 X)
Specifications:
Size Category: Specialty
Type: Analog
Application: Ultra-micro helicopter, cyclic
Torque: 11.6 oz (329 g) force
Speed: 0.13 sec end-to-end
Length: 0.9 in (24mm)
Width: 0.7 in (19mm)
Height: 0.4 in (9mm)
Weight: 0.1 oz (2.9 g)
Bushing Or Bearing: Bearing
Bearing: Single
Motor Type: Brushed
Connector Type: JST-SHR 1.0mm
Gear Type: Nylon
Voltage: 3.2 - 4.2V
Discussion Taranis voltage drops from full to 4V within 10 secs, yet battery full Rotorian Radios 5 Sep 18, 2014 04:14 AM
Discussion Need 5v from a 1s but dont know how!!! servohead117 DIY Electronics 6 Jan 15, 2014 06:23 AM
Discussion LiPo: How low can you go? (voltage per cell) jpegjames Batteries and Chargers 10 Oct 16, 2013 04:35 PM
Discussion How can I lower voltage from 4cell to 3cell superinstaller DIY Electronics 14 Mar 04, 2013 06:18 PM
How can I reduce the voltage of AC/DC Converter? flyingflipper Batteries and Chargers 4 Oct 30, 2004 12:21 PM
