Old Sep 18, 2014, 04:47 PM
United States, MA, Freetown
Joined Sep 2014
Extreme Tail Boom for CX2
http://www.xtreme-production.com/xtr...d5c788bd44034c
I installed this boom for my CX2 I like the the look but the center fin with the 2 black supports in the middle of the boom is flimsy and move around and the support bars will fall off . How can I make them stay on? will a little super glue do the trick for the support arms , how about the center fin in the middle of the tail it's already tight but still moves around? any idea
inkslinger is offline Find More Posts by inkslinger
Old Sep 18, 2014, 05:54 PM
Joined Aug 2008
You could just put a couple of layers of clear tape around the boom at that point, makes it a little bit larger so the clamp will tighten and grab a bit better.
Then you won't need to glue any of it, which just creates an issue if you need to remove any of it later on.
mono is offline Find More Posts by mono
Old Sep 18, 2014, 10:33 PM
Joined Sep 2014
AAhh Tape didn't think of that ! thanks Mono
Old Sep 20, 2014, 11:39 AM
NotAnotherMomentLostToSei zures
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
I use "Sally Hansen Hard as Nails" (clear) to hold plastic to plastic and, also those pesky screws (screw to plastic). Like those 4 screws that hold the boom to the main frame. Just don't use it on O-Rings. It will make them crack and brittle.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Sep 20, 2014, 10:48 PM
Joined Sep 2014
Does that work like a glue? Mike
Mike.
Old Yesterday, 11:31 AM
Chap1012's Avatar
Joined Mar 2008
Not really. But, parts will break free when you want them to. Unlike CA which can be a PITA.
Just put the two parts where you like. Dab the parts where they meet. I usually use two coatings. It dries real fast so you can get through the job in minutes. On a few of my helis the skids always came loose. YUP, Sally Hansen to the rescue.
Some years ago I was faced with the same problem. I didn't want to use CA. As I was sitting out on the deck with my wife and her friend I was discussing my problem. They both (almost in unison) suggested Sally Hansen Hard as Nails. The rest is history and I still use it to this day on many projects.
Mike.
Wanted 2 carbon or plastic rod tail boom fins fin for dragonfly falcon blade CX Cx2 & canopy blueindian Aircraft - Electric - Helis (FS/W) 0 Jun 18, 2010 01:58 AM
Sold Carbon Fiber Tail Boom Kit for Blade CX, CX2 Roswalt Aircraft - Electric - Helis (FS/W) 3 Apr 26, 2009 02:45 PM
Discussion Super Heli Hop Ups Tail Boom for CX2 pd417 Coaxial Helicopters 25 Mar 06, 2009 11:58 PM
Discussion Lama V4, CX2, Axe EZ C Vigilante R/C Horizontal Fin for tail booms vigilante-rc Product Announcements 0 May 18, 2008 05:38 PM
Discussion Carbon Tail Boom for CX2 Philjo Coaxial Helicopters 10 Jan 01, 2008 11:19 PM
