Old Jan 03, 2013, 11:23 AM
galognu's Avatar
United States, NY, Jamestown
Joined Dec 2004
First LEG Build
Well it took me close to two years, though there was a large pause in between, to finish my LEG P-63 Kingcobra.
I purchased the 4 disc DVD and I felt it was a great help. Not sure I would have done as well without it. I also have applied some of those techniques to other build projects.
My biggest issue was with finishing. I did everything as close to the video as I could, but the only difference was since I only have a Lowe's available, I had to use Valspar spray paint instead of the Home Depot stuff, (name just escaped my mind). I ended up using a silver "metalic spray" for the main color, but despite 24 hrs of cure time, it still comes off easily anywhere the plane is handled. Also, I was not able to find the exact low tack tape that Jack recommended. I ended up spending 9 bucks for a "drafting" tape, but not sure it made much of a difference. Anywhere I used take, the silver paint got sort of messed up. Using Yellow was very difficult, as it does not cover well, and needed at least 3-4 coats.
Any suggestions in taping off silver areas would surely be appreciated.
Also, what speed of wind will I need to fly this bird? I will weigh it and post that later. I am in the middle of a move and its freezing out there, so I'm not likely to fly it for a while.
Please give unabashed critique so I can learn. By the way, the paint scheme came off a website called AG-26 squadron: http://www.ag26.org/
Thank you
galognu is offline Find More Posts by galognu
Old Jan 04, 2013, 08:49 PM
chip.greely's Avatar
Carlsbad, Ca
Joined Mar 2007
Not bad for a first LEG build,
..too bad about the fingerprints on the Lowes paint. Can you mist with a Satin Clear coat,...maybe a DEFT product to provide some protection?
chip.greely is offline Find More Posts by chip.greely
Old Jan 05, 2013, 02:52 PM
galognu's Avatar
Joined Dec 2004
Thanks.
Does anyone have a strong preference for the Krylon paints?
Any suggestions for the metallic silver paint?
I did think about a clear coat, and still may do it but I had not seen in suggested in Jack's DVD's.
I'd appreciate any further critique.
Old Jan 05, 2013, 02:57 PM
galognu's Avatar
Joined Dec 2004
Also,
Any good tips on low tack tape and how to prevent the tape from peeling paint off?
Old Jan 05, 2013, 04:39 PM
It's not going to build itself
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
Pretty sweet! Hard to believe it's your first build. Low tack blue tape, for delicate surfaces is pretty good. I think 3m has it with the orange label on the inside of the roll. A bit spendier than the regular blue tape.
TRISME is offline Find More Posts by TRISME
Old Jan 05, 2013, 04:48 PM
Snewk's Avatar
United States, FL, Indialantic
Joined Dec 2011
It's going to look just fine in the air! All else is gravy. Nice build.
Ken
Snewk is offline Find More Posts by Snewk
Old Jan 06, 2013, 09:48 AM
galognu's Avatar
Joined Dec 2004
How about clear coat? Anyone use that in between colors?
Old Jan 07, 2013, 07:53 AM
galognu's Avatar
Joined Dec 2004
Any suggestions as to the wind range this ship will fly it.
Old Jan 07, 2013, 07:58 AM
All work and no play
legliderman's Avatar
Lucas, KS
Joined Apr 2003
Most hills 8mph+
legliderman is online now Find More Posts by legliderman
Discussion LEG 48" Mig 3 build thread soothing Slope 15 Sep 14, 2012 04:55 PM
Wanted Build My Foamie! LEG 48" Mini-D Needs Assembly Indetrucks Aircraft - Sailplanes (FS/W) 2 Aug 10, 2012 11:15 AM
Build Log It's my first time! LEG 1D Build & fly Hangtight Slope 119 Apr 04, 2009 02:07 PM
Sold Leg Jart NIB, with Leg build clinic DVD's stumpeg Aircraft - Sailplanes (FS/W) 6 Apr 30, 2007 07:56 PM
