Old Jul 09, 2012, 03:33 PM
EDF Jet Jam May 2014
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Help!
HET Motor Bearing Dimensions
I have a 700-60-1485 with a sloppy front bearing.
I need to know the OD and thickness, I know the ID is 5mm
Bob
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jul 09, 2012, 04:54 PM
unclecrash's Avatar
white lake michigan
I usually take the bearing out and measure it. I have gotten away with just using a metric ruler on some of my nitro engines.
unclecrash is offline Find More Posts by unclecrash
Old Jul 09, 2012, 05:07 PM
Joined Dec 2000
Thanks for the reply. I want to preorder the bearing in this case.
Old Jul 09, 2012, 07:33 PM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
stu prob has the specs
stoneenforcer is offline Find More Posts by stoneenforcer
Old Jul 09, 2012, 10:44 PM
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
I tried to remove the front and read plate on a 700 series motor and had to make a special puller to remove the from plate on the motor.
I had to use alot of heat in the plate since it epoxied on.
I did not even try to remove the rear plate, since there was no place to pull from.
Hope this helps.
Clay
racer1 is offline Find More Posts by racer1
Old Jul 10, 2012, 05:31 AM
Joined Dec 2000
Hello,
the ID is 5mm, OD is 13mm and the thickness of the bearing is
4mm.
Best regards
HET-RC
-----原始郵件-----
Old Oct 09, 2012, 10:14 AM
Joined Dec 2000
Here's an update the bearing is 13 x 5 x 4.
But how do we get the bearing out???
Well Stu came to the rescue and told me how.
First take two 3mm x 5mm cap hols bolts and thread them into two opposing holes on the front bearing plate. The Cap head bolts will keep the bearing plate from spinning.
Place a metal hose clamp at the back of the motor around the rear bearing plate don't over tighten it.
Take a torch and heat up the front bearing plate area around the circumference of the motor to soften the thread locking compound that the factory uses.
Once hot place the motor front down into your bench vise and turn the motor to the right as it is a left hand thread. The Cap head bolts will keep the bearing plate from spinning.
Be aware that there is a brass spacer washer on the back end of the shaft so don't loose this when you pull the stator out.
Old Oct 09, 2012, 04:55 PM
United States, GA, Alpharetta
Joined Feb 2009
I am guessing that "to the right" means clockwise if it is a left hand thread??? And for a rhetorical question..... why would they make it a left hand thread?
rfodor is offline Find More Posts by rfodor
Old Oct 09, 2012, 09:38 PM
Joined Dec 2000
I have no idea
Old Oct 09, 2012, 10:43 PM
Not Funny......
Mike Warren's Avatar
United States, CO, Redstone
Joined Dec 2010
So the motor torque tightens rather than loosens the front plate when running.
Mike Warren is offline Find More Posts by Mike Warren
Old Oct 10, 2012, 05:32 AM
Joined Dec 2000
Nah they just decided to mess with us.
Old Oct 10, 2012, 05:52 AM
Joined Feb 2009
I agree, the motor can run in either direction.
For Sale like new 600-42 het motor with stator ring FLYBABE Aircraft - Electric - Jets (FS/W) 3 Jul 04, 2012 12:59 AM
Discussion NTM motor bearing change? whakahere Power Systems 4 Jun 24, 2012 08:08 AM
Sold HET 6404 fan + Wicked 4000 KV motor The Don Aircraft - Electric - Jets (FS/W) 19 Jun 21, 2012 09:57 PM
Discussion HET motor bearing Benovitch Electric Ducted Fan Jet Talk 7 Aug 06, 2011 03:04 PM
Discussion HET motor bearing Benovitch Electric Motor Design and Construction 0 Jul 30, 2011 01:02 PM
