Old Jan 21, 2010, 05:28 PM
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Sloyak28" 32"
Ok everyone I took two great epp planes and made
a few changes to them and made what I think is a
even better plane!
I call it the SLoYak28
the plane was designed around the slofly28 designed
by Sloper Steve& Gene bond
to build this kit you need to download the 2 sets of plans
below "they are free of course"
Building
print and tape together the 2 fuselage parts of both planes
and the tail section of the Yak55 (just the rudder piece)
also tape together the wings and the elevator pieces from the
slofly28 set of plans.
I used standard 8 1/2 x 11 typing paper.
(tip if you printer will take card stock use it as it makes
a better template)
Stay tuned a video will show you the basics of how I merge
the two plans to build one.
Parts used on plane kit
1 sheet 18 x 36 1.3# 9mm epp foam
2. 3mm x 1000mm carbon rods or tubes
1. blue wonder 1300kv outrunner From Hobby King.
1. 3mm prop saver
1. epp motor mount
1. 10 amp esc
3. blue bird 306 micro servos
1. gws 4 channel rec
1. gws 9050 prop
1. 7.4 volt 300-500 mah (20C) lipo (remember ligher is better) 250-350mah is what I like.
1. dubro Mini E/Z Connectors #845
2. dubro Micro Control Horn- Narrow #848
1. dubro Micro E/Z Link #849
1. dubro 30” Micro Pushrod System #852
1. 1/32 sheet of lite ply (used for control horn stiffners)
1. 5 minute epoxy
1. hot glue gun with low temp sticks
1. roll strapping tape (staples) the kind with fiberglass strings in it.
1. x-acto knife # 11 blades
1. medal straight edge ruler 18" or longer works best.
1. set wire cuters
1. 1. small screw driver set
(optional items)
Dremel with cutting tool or Soldering iron to cut groves in foam for carbon.
use what methods works best for you.
tallflyer is offline Find More Posts by tallflyer
Old Jan 21, 2010, 11:58 PM
tallflyer's Avatar
Joined Jul 2002
Here is The sloyak32 "Final Version"
This plane was created using google Sketchup I went with a larger wing 32" as i wanted a ligger larger wing area, I also moved the Elevator forward a little.
The Sloyak32 video
Epp Yak30 Plane (2 min 38 sec)
Sloyak28/32 plans
The plane in the video is using this setup.
Bluewonder 1300kv motor
GWS 9050 prop
2 cell 7.4volt 360-500mah lipo (20-25C) discharge
3 towerpro 5 gram servos
1 gws 4 channel rec
All dubro connectors and ez-connectors
10amp budget esc (brushless)
3.0 mm carbon for wing and fuselage + elevator
1.3# 9mm epp foam for plane
Hot glue for hinges
Hot glue for build
Strapping tape to hold servos and stuff in place
AUW with 2 cell pack Just 6.5oz
Download the Complete plane Plans below.
Old Jan 22, 2010, 12:14 AM
tallflyer's Avatar
Joined Jul 2002
More Videos
More Videos
EPP Sloyak28 Maiden Flight
EPP Sloyak28 Maiden Flight (2 min 30 sec)
Sloyak28 with Motrofly motor
Sloyak28 with motrofly 2205-1350 brushless motor (3 min 24 sec)
Sloyak28 More Flying
EPP foam Sloyak28 Airplane (3 min 27 sec)
New sdyak32
http://www.youtube.com/watch?v=B6Wp1eznN_U
Latest blog entry: New GoPro Hero3+ Black Edition
Old Jan 23, 2010, 09:55 PM
Lakeville Minnesota
SailingAlong's Avatar
Lakeville MN
Joined Oct 2008
What I want to know Rob, is how you get everyone to move their cars out of the parking lot when you maiden and fly your planes
Steve
SailingAlong is offline Find More Posts by SailingAlong
Old Jan 23, 2010, 10:19 PM
tallflyer's Avatar
Joined Jul 2002
It's a county parking lot and they are closed on the weekend so I get to have the place to myself most of the time
Old Feb 03, 2010, 01:37 PM
tallflyer's Avatar
Joined Jul 2002
New Video From last weekend
I have not flown this plane in Awhile so I thought I would shoot a new video of me cranking it through a few flights.
EPP Foam Sdyak32 Airplane Video # 1 (2 min 40 sec)
Old Jul 12, 2010, 07:36 AM
Heart of Dixie
Joined Oct 2009
repost from other thread....great plane,
SloYak-28.mpg (0 min 58 sec)
Blackcloud is offline Find More Posts by Blackcloud
Old Jan 26, 2011, 01:29 PM
tallflyer's Avatar
Joined Jul 2002
Great plane
Great plane fly's awsome and is easy to build.
For Sale Kontronik Fun 600-18, 4.2:1, and Jazz 55 10 32 used davecee Aircraft - Electric - Power Systems (FS/W) 4 Mar 24, 2010 05:14 PM
Discussion strippers . . . and crimpers for 32 AWG Kookaburra DIY Electronics 8 Jan 12, 2010 04:16 PM
Sold Du-Bro Sheet Metal Screws NIB 32 screws for $3.00 shipped jodini Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 12:43 PM
Discussion Plans needed for Eflite Power 32 Daddy-O Foamies (Scratchbuilt) 7 Jan 10, 2010 12:41 AM
