Old Dec 14, 2013, 10:55 PM
United States, TN, Signal Mountain
Joined Sep 2007
Help!
Help painting Cowl and Wheel Pants
As you can see in the attached picture, I have spent a lot of time covering my Goldberg Super Chipmunk. Now, itís time to paint the cowl and wheel pants (they are fiberglass from Fiberglass Specialties). However, Iíve never done this before and really have no idea what Iím doing! Iíll be using a glow engine, so the finish has to be oil resistant. Iím trying to do a decent job without breaking the bank.
These are the steps that I have pieced together after reading other posts and articles.
  1. Wash with soap and water
  2. Block sand with 220 grit (dry)
  3. Blow out all dust with air gun
  4. Coat with glazing putty to fill pin holes
  5. Wet block sand with 220
  6. Spray with primer
  7. Wet block sand with 600 grit
  8. Spray final paint (use 3M thin vinyl tape to mask)
Iíll be using a Preval Spray Gun to spray the paint.
Here are my questions:
For the primer, will Rust-Oleum Automobile primer in a rattle can from Home Depot do the job, or should I use a more expensive filler primer from an automotive store? (I picked up a can of Dupli-Color Filler Primer from OíReillyís, but itís twice as much as Rust-Oleum)
For the white, I plan to use Rust-Oleum oil-based protective enamel gloss white. Will that do the job? Do I need to thin it any before spraying it?
For the red: Any tips on how to match the red covering? I went by OíReillyís and learned that the smallest size of their least expensive automotive paint would cost about $50 once I bought the hardener, etc. The covering is Sig Aerokote, so there isnít a matching rattle can paint I can buy (like LustreKote).
Is it necessary to spray a coat of clear coat on the finished product? If so, what brand/type.
Any tips on how to mask both sides of the cowl so that the curves match?
Thanks for your help!
ktrails is offline Find More Posts by ktrails
Old Dec 15, 2013, 08:36 AM
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
In my opinion, you have some steps out of order.
My schedule would be to
wash with dish soap and warm water
sand with 220
Blow with air gun and then wipe clean with a solvent wetted cloth
prime with Duplicolor high build sandable primer
sand with 300 to expose high and low spots
use glazing putty for low spots and pin holes-repeat as necessary
spray with Duplicolor high build
sand with 300
spray top coat
I have never used Rustoleum primer. Although I use Rustoleum top coats I strongly suggest that you use an automotive high build primer. It is sandable and dries quickly. It is designed to do the very thing that you are planning. Duplicolor makes a readily available primer. You get what you pay for.
The glazing putty tube states to use it over primed surfaces. Do not apply it to bare wood or fiberglass. The putty "eats" into the lacquer based primer, forming a chemical bond. It just sits on top of glass, forming a weak, mechanical bond.
Rustoleum white should work well. The can states to thin it with acetone, or mineral spirits. I thin to the consistency of milk. Maybe 40% thinner?60% paint.
I spray a test panel to check viscosity and spray pattern.
You have discovered why I paint entire airframes. Finding a quality, color matching paint is nearly impossible. Automotive paint will probably attack your Rustoleum, anyway.
Here's my suggestion. Rustoleum has at least 3 Reds. Pick the one closest to your covering, and use it.
Although most paint will easily go over most brands of automotive primer, I would suggest that you stick with one brand, when it comes to color coats and clear coats, if you use one.
I do not clear coat my Rustoleum painted models, both gas and glow.
To mask the sides evenly, make a template for your design. Use it to transfer masking outlines to the surface. Repeat for the second side.
I suggest that you let you paint thoroughly dry before spraying each additional color. I like to wait at least a week.
After the first day, set your painted parts in the sun, if possible. The UV helps to cure the paint.
Also, since you are painting just the cowl and wheel pants, I suggest that you purchase aerosol cans instead of quarts. Unless you plan to use the same colors, multiple times, it will probably be less expensive to buy the spray cans.
Rustoleum's aerosols spray well. Although most of my airframes are sprayed with an HVLP gun, I have painted models with Rustoleum aerosol cans. The finish turned out well.
This model was painted from aerosol cans.
TomCrump is online now Find More Posts by TomCrump
Old Dec 15, 2013, 08:41 AM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Notice that I suggested 300 grit for final sanding. 600 grit tends to polish the surface. The 300 will leave a more coarse surface, allowing your color coats to have better adhesion to the primer.
Old Dec 15, 2013, 09:01 AM
Joined Sep 2007
Tom, thank you for the thorough reply. This is very helpful!
Old Dec 15, 2013, 10:08 AM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
I have not priced one yet, but I heard that my local paint shop, that carries automotive paints, will mix up a rattlecan for you.
they can color match from your covering, and put it in a spry cay for ya!
like I said, I have not priced one yet, I doo know that auto colors are not cheap!
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: great day!
Old Dec 15, 2013, 11:29 AM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Back in the 60s, I had that done. If I remember correctly, I got two cans for $.7.00.
At roughly 10 times that, now (inflation), I would assume the costs to be prohibitive.
Old Dec 17, 2013, 07:07 PM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I have a lot of experience with Fiberglass Specialties parts, and one thing I insist on is sanding every square inch of the part with care, to remove all glossy areas.
Final sanding with some detergent before priming is recommended.
Then follow all Tom's suggestions...He and I have become highly experienced with Rustoleum paints (I use rattle cans, he does spray guns) over the last few years.
Rustoleum is glow and gas proof after about a week of drying.
Nice looking build....
Earl.
epoxyearl is online now Find More Posts by epoxyearl
Old Dec 17, 2013, 08:06 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
atleast he should be using good ol red, white, and blue!
Old Dec 18, 2013, 12:23 PM
Flying 2 Fight Cancer
Elec 1800's Avatar
corona, ca
Joined Feb 2011
here is a Cowl and Wheel pants from a 1/3 scale Corby starlet that i recovered and used rattle cans to paint. Used automotive Filler primer and Valspar spray cans from Lowes as well as Valspar Clear coat.
I also painted the Pilot with the same paint/primer
Elec 1800 is offline Find More Posts by Elec 1800
Old Dec 18, 2013, 04:49 PM
epoxyearl's Avatar
Joined Oct 2011
Nice JOB !! I can appreciate the hard work and preparation.
That kind of work doesn't get done in one sitting...
Earl.
Kudos.
Latest blog entry: Just thinking out loud
Old Dec 18, 2013, 06:29 PM
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Earl.
Kudos.
Thanks Earl, yeah it a couple of sittings She was a 3 month project
Old Jun 27, 2014, 02:29 PM
Joined Sep 2007
I finally finished painting my cowl -- I'm very pleased with the results. Thanks for the help! For the red paint, I ended up going to a local automative paint store. They did a color match on the covering and mixed up a spray can of machine enamel for $18 -- after doing the paint match, they took some time to tweak it to get a good match (thanks Tim!). I'm very pleased with it.
One issue is that the paint has a bit of an orange-peel look to the texture -- I think this has to do with my lack of experience with the spraying process (you can see it where the light is reflecting in the picture). Is there anything I can do about it now, such as sand with very fine paper (1200 grit)? If I do sand it, wouldn't I have to put a clear coat on it? If so, what is a good one to use without breaking the bank (Rustoleum?)?
Old Jun 27, 2014, 05:15 PM
epoxyearl's Avatar
Joined Oct 2011
lumpy bumps (orange peel)
Yes a sanding is in order, and when it's nice and flat looking, with no glossy spots, you can spray clear over it,and get the color back, - if you don't sand through anywhere..A second coat of Red would be a better choice.
I'd suggest setting the spray can in fairly hot water to thin it (either the Red or the Clear),and wiping the can dry before spraying the hot paint on the cowl. The warm paint will flow much better.
Old Jun 28, 2014, 12:53 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
exactly! I use the hottest water I can get out of my tap, give it (the can) a good shake while filling up a small pot, let sit in hot water for a few, then give it another good shake!
and if your gonna wet sand, I would put another coat or two!
Old Jun 28, 2014, 11:23 AM
Joined Sep 2007
Thanks for the advice EpoxyEarl and whiskykid. So, it sounds like sanding and hitting with another coat or red is the best option (after letting paint can sit in hot water). What grit sandpaper would you recommend? Also, what about the line between the red and white - I'm thinking if I sand that out, again, I have to hit with clear coat?
Question Need Cowl and Wheel Pants for Carl Goldberg Ultimate Biplane ita47 Fuel Plane Talk 3 Sep 19, 2013 12:03 PM
Wanted Someone to paint my cowl and wheel pants to match my plane/Michiana area! flyinjrc74 Aircraft - General - Miscellaneous (FS/W) 1 Jan 11, 2010 11:16 AM
WTB: Cowl and wheel pants for Kyosho Pitts 40 Dukester Aircraft - Fuel - Airplanes (FS/W) 5 Feb 23, 2005 09:40 AM
Cowl and wheel pants JimRoss Aircraft - Fuel - Airplanes (FS/W) 0 Dec 12, 2004 08:03 PM
looking for supplier of cowlings and wheel pants Ranfred Radius Electric Plane Talk 3 Aug 27, 2003 06:22 PM
