Old Apr 07, 2013, 04:17 PM
The high desert of Southern California
Joined Jul 2002
What kind of foam is this?
Has any one used this stuff before? Can the paper be taken off without to much trouble?
Wonder what the shipping is on a box of 25, 48x96 foam boards?
I did a search on here but found nothing.
http://www.jerrysartarama.com/discou...s-pro-foam.htm
Buzz.
blvdbuzzard is offline Find More Posts by blvdbuzzard
Old Apr 07, 2013, 07:01 PM
treefinder
springer's Avatar
SE MI
Well, I suspect it's just styrene based foam with expensive acid free paper for the matting folk. it's more than twice as expensive as Dollar tree foam (readiboard) in the 3/16x20x30 size using the "sale" price. I don't think I'd bother with it. Look for a dollar store that sells the Readiboard 3/15" paper off) in the office or craft section for the cheap way to go for small amounts, or you can get a box of 16 sheets of 24"x48" Model Plane Foam for $65 delivered.
springer is offline Find More Posts by springer
Old Apr 08, 2013, 10:25 AM
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
What springer said. This appears to be higher end stuff. Shipping at Dollar Tree is included in the $1 price. Of course, there's always MPF as an alternative.
potshot is offline Find More Posts by potshot
Old Apr 08, 2013, 12:43 PM
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
That also looks to have a posterboard covering. If you have never tried to remove posterboard from foam before, its a nightmare and a mess.
Readi-Board from dollar tree really is the simplest solution for most. MPF is good for if you want larger panels without the waves that Ready-Board has. Both you can glue peices together to make larger pieces.
OutcastZeroOne is offline Find More Posts by OutcastZeroOne
Old Apr 08, 2013, 01:29 PM
Romans 8:34-39
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
MPF has been the best I've used so far, including styrofoam, fan fold foam, dollar tree foam, and depron.
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Apr 08, 2013, 06:40 PM
Joined Jul 2002
I was curious because of the sizes. I have plenty of the dollar store foam sitting here. I soak it with water, let dry and peel the paper off with ease.
Buzz.
Old Apr 08, 2013, 07:14 PM
Joined May 2005
I dont even wet the Readi-Board anymore. The papers bond is so weak now it comes right off.
Old Apr 11, 2013, 05:48 AM
psychedvike's Avatar
United States, MN, Shoreview
Joined Aug 2012
forgive the dumb question but what is MPF and where can you get it
psychedvike is offline Find More Posts by psychedvike
Old Apr 11, 2013, 08:04 AM
treefinder
springer's Avatar
SE MI
Model Plane Foam available at modelplanefoam.com
Old Apr 11, 2013, 09:22 PM
Joined May 2005
its made by Adams PLastics, the same company that also made Ready-board and some of the FFF. its basickly FFF but white and without any backing and 6mm thick. It also got a uniform surface, unlike Readi-board with its wavyness.
Help! What kind of plane is this BigPapaFreeze Beginner Training Area (Aircraft-Electric) 13 Mar 27, 2013 03:15 PM
Discussion What kind of motor problem is this??? Tanthalas Micro Helis 1 Feb 27, 2013 01:37 AM
Discussion does anyone know what kind of heli is this? jahk20 Electric Heli Talk 11 Jan 21, 2013 11:44 PM
Discussion What kind of foam is this? IWC Foamies (Kits) 5 May 02, 2006 12:26 PM
Anyone know what kind of foam this is? duanecowgill Foamies (Kits) 3 Aug 28, 2002 11:01 PM
