Old Aug 18, 2015, 12:39 PM
zaid21 is offline
Find More Posts by zaid21
Joined Jan 2015
Help!
Help with electronics
hey all,
Gona be doing my first scratch build and i decided on doing the one on the Flite test website the 'FT Flyer' seems pretty simple to do and they have a nice video on it. But since i live in India i need help the electronics, now i dont really wana buy from hobbyking and all those wesbites becuse ill have to wait for a long time and they'll have chargers on the delivery so could anyone please help me out from choosing my electronics on www.rcbazaar.com? if you could suggest me all the electronics on that site itll be a big help, i have looked at few of em but id leave it to you guys becuz youll know it better.
RC im building: http://flitetest.com/articles/FT_Flyer_Scratch_build
Suggested electronics on the site:http://flitetest.com/articles/swappa...peed-build-kit
Thank you!
zaid21 is offline Find More Posts by zaid21
Old Aug 18, 2015, 02:55 PM
WombatControl is online now
Find More Posts by WombatControl
WombatControl's Avatar
Joined Jul 2011
That store doesn't have exactly the setup you'd need, but it's possible to get close enough.
The typical motor for the FT Flyer is a 24g "Blue Wonder" style motor. RCBazaar doesn't have one, but this is fairly close in terms of size and thrust:
http://www.rcbazaar.com/product.aspx?productid=4097
You'll need a roughly 12A ESC. This should be fine:
http://www.rcbazaar.com/product.aspx?productid=2443
You also need 2 9g servos, like these:
http://www.rcbazaar.com/product.aspx?productid=794
Do you have a radio system? I have no idea how well this radio would work, but it's probably good enough to start with:
http://www.rcbazaar.com/product.aspx?productid=2011
That site does have Graupner radios, which are quite good - Flite Test uses them now.
These props should work OK:
http://www.rcbazaar.com/product.aspx?productid=323
Finally, this battery is in about the right size category for a Flyer:
http://www.rcbazaar.com/product.aspx?productid=2461
One problem I see is that your ESC has a T-style connector and this battery has a JST Adapter. You can cut off the T-plug from the ESC and replace it with a JST from here:
http://www.rcbazaar.com/product.aspx?productid=1336
JSTs don't get soldered on, they get crimped onto the wires, so that will save you some soldering. But be careful when you put on the connectors - look at some YouTube videos first to see how it's done.
Do keep an eye on how heavy your plane is. I don't know what kind of foam you can get in India, but you want to make sure your weight is right about where it's listed on the Flite Test plans to make sure it flies well.
Good luck with the build!
WombatControl is online now Find More Posts by WombatControl
Discussion Help with electronics for mini Crack Yak icy_wind500 3D Foamies 3 Aug 19, 2015 11:43 AM
Discussion First Gas Plane-Help with electronics Corellis Fuel Plane Talk 15 Aug 11, 2015 09:51 PM
Help! I am building a FT flyer (BluDart) and need help with electronics! region Foamies (Scratchbuilt) 11 Jan 06, 2015 04:12 AM
Discussion Electronic help with bec mensite Electric Plane Talk 3 Mar 17, 2014 11:14 AM
Help! Help with rcexl electronic ignition Jriddell Fuel Plane Talk 7 Jan 29, 2014 05:33 PM
