Old Sep 21, 2012, 09:48 PM
racerboy65 is offline
Find More Posts by racerboy65
United States, WI, Fond du Lac
Joined Sep 2011
Help needed
Hi all
I am looking looking to replace this motor HK2445-3200 that I have in my small version of the Het Tucano. Its a car motor I know. Im running a 36amp thundrbird esc with a 1300 3s lipo biggest battery i can fit. 4.5x4.1 prop. The motor gets tired really fast I actuall had two of them and the first one lasted about 15 flightsand performance was way down.I was pulling 338w,34 amps and dont remember volts. I know that Im over amping it by almost double now that I put it on a meter. Im thinking a Mega 16/15/3 would be a good fit but thats a little pricey for me. Anything comparale to that?
racerboy65 is offline Find More Posts by racerboy65
Old Sep 22, 2012, 04:06 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Het 3W
ARC 28-37-2.5
Himax HB2816-3000
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Sep 22, 2012, 12:25 PM
Joined Sep 2011
The HET looks like a good one as far as amps and watts. I just wonder with the 1350 battery will I be getting the same performance speed wise that I have now or better. I like to go fast.
Old Sep 22, 2012, 03:10 PM
Joined Jan 2001
Due to the lower Kv you may need to run a slightly larger prop, eg. 4.7x4.25. With this prop my motor got 374W and 109mph static pitch speed. YMMV.
338W / 34A = 9.94 Volts. If this is correct then your battery may be the limiting factor. To handle 34A a 1350mA battery should be rated for at least 25C continuous, but 40C+ would be preferable.
Old Sep 22, 2012, 04:09 PM
Joined Sep 2011
So what's your estimate on air speed then?
Old Nov 23, 2012, 01:27 AM
XtremeWingRC is online now
Find More Posts by XtremeWingRC
Houston, Texas
XtremeWingRC's Avatar
United States, TX, Bellaire
Joined Oct 2007
I've used het motors all the time.
On a 3w 3000kv 4.1 pitch
On 3s I guess
Pitch speed is 129mph - drag
So 100 mph plane is my guess or maybe a little more.
Get a radar gun!!!!
XtremeWingRC is online now Find More Posts by XtremeWingRC
Discussion Need help. Need new motor Robrotor Power Systems 1 Jun 12, 2012 08:46 AM
Question About to buy a motor and need help deciding what one I need!!!!! bluemeane 3D Flying 4 Mar 14, 2012 10:49 AM
Discussion About to buy a motor and need help deciding what one I need!!!!! bluemeane 3D Foamies 8 Mar 08, 2012 09:40 AM
Question About to buy a motor and need help deciding what one I need!!!!! bluemeane Electric Plane Talk 14 Mar 07, 2012 11:14 AM
Discussion About to buy a motor and need help deciding what one I need!!!!! bluemeane Parkflyers 0 Mar 02, 2012 12:15 PM
