Old Jan 20, 2005, 07:43 AM
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
XRB droopy blades no different
In an attempt to increase the agility i applied tape to the underside of the blades while bending them down. This induced a droop of about 8mm static. In the air they coned up less but the flight chargecteristics remained much as they were.
Oh well it didnt cost me anything to find out.
Terry Rigden is offline Find More Posts by Terry Rigden
Old Jan 20, 2005, 09:32 AM
Toms River Rj Miller, New Jersey (excl EWR), United States
Joined May 2003
I find that under continued use, the blades "soften" in the area ajacent to the black hard plastic. This increases the "coning" and eventually causes the blades to go out of tracking. To prevent this, I inserted a very thin straight pin CAREFULLY thru the blade lengthwise from the attachment end toward the tip. This gives the blade a "spine" past the point where softening occurs without adding significant weight. My blades still cone but do not get too far out of line
rcflyrdon is offline Find More Posts by rcflyrdon
Old Jan 20, 2005, 12:22 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
I have the tethered XRB. FWIW, I discovered the hard way that the blade area at the root grip can fatigue. I did not pay close attention to this wear and my only crash to date was a spectactular in-flight display of carnage when a blade was thrown like a dart. I now use a strip of kapton tape at the root ends to extend the life of the blades.
RC-CAM
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Old Jan 21, 2005, 03:20 AM
UK, Bedworth
Joined Apr 2004
Thanks for the info guys , both solutions look good, I'll give them a try.
Reagrds
Terry
XRB, Stiff blades and outdoor flight Swilson50 Coaxial Helicopters 1 Feb 02, 2005 12:30 AM
XRB CF blades Cable Guy Coaxial Helicopters 3 Jan 20, 2005 11:15 PM
Hirobo xrb sr blades mr b Coaxial Helicopters 5 Nov 23, 2004 11:23 PM
XRB carbon blades stickyfingers Coaxial Helicopters 14 Oct 30, 2004 04:23 PM
(cut Blades No Go) jmctague Micro Helis 4 Dec 05, 2003 11:24 PM
