Old Apr 12, 2012, 03:49 PM
Joined Feb 2012
Hitec HS-55 servo humming
Hi there
I'm building my first ARF plane which is an FlyFly PT-20 Ryan.
Currently I'm trying to adjust the ailerons servo, which seems to hum. I made a video, can anyone eventually tell if this amount of humming is normal?
Specs:
Hitec HS-55 Servo
Receiver: Spektrum AR600
Spektrum DX6i
40A noname ESC
Thanks!
Hitec HS-55 Servo humming (0 min 31 sec)
weeheavy is offline Find More Posts by weeheavy
Old Apr 12, 2012, 04:43 PM
Joined Aug 2002
Originally Posted by weeheavy View Post
Hi there
Specs: Hitec HS-55 Servo Receiver: Spektrum AR600
Spektrum DX6i 40A noname ESC Thanks!
1. A few new servo do hum for a period whilst settling down,
this usually goes away after servo has been "worked" for a few minutes.
2. Try removing horn, if AOK, most likely causes:
a) Hinges are not in a straight line, or working freely with perhaps an excess of
glue on hinge(s) which needs to be worked out.
b) Mechanically incorrect. Control rods perhaps not square to horns and
putting incorrect pressure on horn which may cause binding.
c) Servo - Burnout. Cause & Prevention
and many more reasons covered under sub Section:
"Glitches & Jitter in Receiver, Servo & ESC - causes and cures " under
"Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline Find More Posts by A.T.
Old Apr 13, 2012, 05:22 PM
Joined Feb 2012
Thanks! I'll try to analyze the cause.
Old Apr 14, 2012, 01:01 PM
TigreJohn
United States, CA, Corona
Joined Aug 2008
Try loosening up the fit of your EZ Connectors to the servo arm. From what I saw on your video these are too tight and bending the pushrods.
jjkupinski is offline Find More Posts by jjkupinski
Old Apr 14, 2012, 06:24 PM
Joined Dec 2009
Control serfaces are binding
Hi there
Specs:
Hitec HS-55 Servo
Spektrum DX6i
40A noname ESC
Thanks!
http://www.youtube.com/watch?v=qqpbVASvGLQ
Disconnect the servo horn from the servo, the push-rods should move easy with very little resistance, binding will cause damage to the servo and discharge your rx battery quickly. A amp meter on your rx battery during servo setup is the best way to detect binding. good luck
Derek
derek4610 is offline Find More Posts by derek4610
Sold Like new Hitec HS-55 Economy Feather Sub Micro Servos thundercl58 Aircraft - General - Radio Equipment (FS/W) 1 Mar 29, 2012 05:07 PM
For Sale Hitec HS-55 Feather Servos (4 total) New Roly72 Aircraft - General - Miscellaneous (FS/W) 2 Jan 10, 2012 01:17 PM
Wanted Hitec HS-55 Servos RCMattG Aircraft - General - Radio Equipment (FS/W) 0 Nov 29, 2011 08:41 AM
Sold Three Hitec HS-55 Servos NIB $25 shipped CONUS parkflyer215 Aircraft - General - Radio Equipment (FS/W) 5 Nov 22, 2011 11:29 AM
Rant Hitec HS 55 Servos Rob1962 Fuel Plane Talk 4 Oct 20, 2011 08:51 PM
