Old Oct 11, 2014, 01:55 PM
k2roo's Avatar
Australia, VIC, Melbourne
Joined May 2013
Sorry for so many questions but i am now regreting buying this jet even more. Trial fitting the air retracts, i wouldnt say excessive force was used, and the brass bullet connector on the side just snapped! Far out.
So i am hoping you guys may have a solution. The side connector doesnt seem to screw out like the end connector does.
k2roo is offline Find More Posts by k2roo
Old Oct 11, 2014, 02:30 PM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Don't know on the retracts problem. I think that glassing the center joint is over kill. There isn't much stress at that point, and the carbon rod carries the load as you said. I've neverread aabout any of the Sniper series failing at that point. That mod has never made any sense to me.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Oct 11, 2014, 02:35 PM
k2roo's Avatar
Joined May 2013
As you said......Overkill
Old Oct 11, 2014, 06:07 PM
k2roo's Avatar
Joined May 2013
What sort of wood did you use knife for your retract mod?
Old Oct 11, 2014, 06:21 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Most likely a press fit then- I'd pull of the side plate and give it a twist-- see what happens- You can't break it any more than it already is!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 11, 2014, 08:17 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
+1 ...agreed
Old Oct 11, 2014, 08:21 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
That is White Pine from. Home Depot I think. Any light hardwood like bass, or pine will work. Looks like the factory used the trunk of the bushes out behind the building. LOL
Old Oct 11, 2014, 08:54 PM
USA, TX, The Colony
Joined Dec 2005
Lee - have you flown yours yet?
cquian is online now Find More Posts by cquian
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 705 Oct 04, 2014 07:08 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 12:37 PM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 12:10 PM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 09:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 10:17 PM
