Old Jul 28, 2014, 07:10 PM
Iceland, Capital Region, Reykjavik
Joined May 2012
Question
Has any one bought FB off aliexpress?
I was thinking about buying this to build a delta wing. Any reason I shouldn't use this FB?
mummi is offline Find More Posts by mummi
Old Jul 28, 2014, 10:18 PM
elmagnificado's Avatar
United States, TX, Austin
Joined Jan 2013
Because it's over $12 for a very small piece of foam. Not worth it in my opinion. Dollar tree foam board is your best bet if your just going to build a delta wing.
elmagnificado is online now Find More Posts by elmagnificado
Old Jul 28, 2014, 10:30 PM
Joined May 2012
Where can I buy dollar tree FB that ships to EU?
Old Aug 01, 2014, 10:53 AM
CNC Cutter
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
That add says its PVC - much too heavy !
Too expensive for 15" x 11" x 7mm piece of foam.
Our Model foam is Styrene Styrofoam either EPS Expanded or EXP Extruded.
RCFoam.com can send cases of the stuff to you.
If they wont I will send you via mail either Depron or MPF.
What Girth limitations does Iceland have via the Mails ?
I can cut down the Depron or MPF to achieve 79" girth limitations.
Just Cost + shipping.
Bob
Hoosier Cutout Service
birdofplay is offline Find More Posts by birdofplay
Old Aug 01, 2014, 01:16 PM
Joined May 2012
Bob
I might have found a craft shop that sells usable foam board. I bought a 1000700 mm 5mm thick board. I am going to try it out next week. If it's not usable ill contact you, thanks.
Old Aug 01, 2014, 03:02 PM
CNC Cutter
birdofplay's Avatar
Joined Dec 2005
Good find !
Best of luck.
Bob
Discussion has any one ever tryed storm launcher guts on an osg glider jrc35 Foamies (Scratchbuilt) 2 Oct 06, 2013 08:47 PM
Discussion Has any one bought from 3D Fly? AA5BY Fuel Plane Talk 0 Mar 09, 2011 06:43 PM
Discussion has any one bought the 58% bill hempel decathlon live_to_fly Giant Scale Airplanes 3 Jan 11, 2011 06:34 AM
Discussion Has any one bought this before? bamm Electric Sailplanes 0 Mar 20, 2008 08:13 AM
Discussion Has any one bought from RC Smart jypt Vendor Talk 1 Jul 20, 2006 01:47 AM
