Old Jul 19, 2014, 05:15 PM
Pesty351's Avatar
Tyndall AFB FL
Joined Oct 2009
What cub is this? 105" WS
Hi,
I'm trying to figure out who made this cub so I can get a replacement windscreen. I picked it up from a friend of mine who has had it hanging from a ceiling for a couple decades. All I can really say is it has a 105" ws and is old, fabric covered, and completely awesome.
Pesty351 is offline Find More Posts by Pesty351
Old Jul 19, 2014, 08:40 PM
I hate spray cans
don olsen's Avatar
United States, NM, Rio Rancho
Joined Jul 2007
From the pics it looks like a 1/4 Sig cub. most Cubs of this size the windscreen is made from flat stock. The pattern is on the plans if you can find one Other than that get some poster board and cut to fit then make one from clear flat stock
don olsen is offline Find More Posts by don olsen
Old Jul 20, 2014, 02:19 AM
United States, TX, Leander
Joined Sep 2003
I would go with sig too. I have two busa 1/4 scale cubs and the cabin area is built different than sig. I'm pretty sure that is not busa. A picture of the tail section and how the ailerons are set up might help.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Jul 20, 2014, 06:23 AM
I hate spray cans
don olsen's Avatar
Joined Jul 2007
The Sig doesn't have the opening window and door on the right side the BUSA does
Old Jul 20, 2014, 12:19 PM
Pesty351's Avatar
Tyndall AFB FL
Joined Oct 2009
This one has an opening window on right side but not the door. I'll get some pictures of the rest of it to see if that helps.
Old Jul 20, 2014, 12:36 PM
Canada, ON, Newmarket
Joined Mar 2005
Sig Cub. The bulkhead behind the windscreen is the clue.
The opening window would be a mod.
You don't "get" the windscreen. You make it -from flat plastic stock, as the others have said.
What you do get is the manual, direct off the web, from Sig. In the very last pages you will find a printed template to cut the windscreen from the mentioned flat plastic stock.
Make your template by trial and error trimming until you are satisfied with the fit, then cut that shape from the plastic sheet. Attach with your favorite method. The manual describes how to do it as well.
Not hard although a bit fiddly to get it to match your particular plane.
ar196 is offline Find More Posts by ar196
Old Jul 21, 2014, 10:38 AM
Expert in sawdust production
flyerinokc's Avatar
United States, OK, Oklahoma City
Joined Aug 2007
The minute I saw it I said SIG 1/4 scale. The construction matches it to a T.
flyerinokc is offline Find More Posts by flyerinokc
Old Jul 21, 2014, 11:38 AM
I hate spray cans
don olsen's Avatar
Joined Jul 2007
http://www.sigmfg.com/BuildManuals/SIGRC48CubP4.html
Try this for your pattern
Old Jul 22, 2014, 05:54 AM
Pesty351's Avatar
Tyndall AFB FL
Joined Oct 2009
Thanks people. You guys rock!
Old Jul 22, 2014, 02:19 PM
Joined Dec 2013
Nice find, definitely a sig... from the looks of it, it has the 2 piece wing mod, which sig should have done originally... I've got a 15 year old sig cub I'm restoring and modifying the wing into a 2 piece / fixed center section (same as yours)... you'll enjoy it, no doubt about it.
John M,
John_M_ is offline Find More Posts by John_M_
Old Jul 22, 2014, 11:30 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
My sig the wing splits on one side of the fuse not on both sides. the wing is the top of the fuse. So unless they made 2 designs its not sig.. or it was a mod...maybe
Old Jul 23, 2014, 08:27 AM
Joined Sep 2003
I would guess its a mod.
Edwin
Old Jul 23, 2014, 02:31 PM
Joined Dec 2013
Its a Modification turbonut... the wing is built in three separate pieces, right wing - center section - and left wing... the center section is then glued onto the upper fuselage and reinforced... you can either use the plywood brace, or utilize a wing tube... I don't recall where the Mod originated, but it's better than the 2 piece / bolt on wing sig originally had... it works very similar to the Hangar 9 1/4 Cub wing attachment.
John M,
Old Aug 03, 2014, 08:31 AM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I have the sig plans-I can send you a copy of the w/s pattern, if you like.
The pattern still needs trimming to be an exact fit for your model.
PM your mailing address....I'll mail you a copy.
epoxyearl is offline Find More Posts by epoxyearl
Old Aug 06, 2014, 09:28 PM
Pesty351's Avatar
Tyndall AFB FL
Joined Oct 2009
Thanks y'all I've got it all together ready to go!
Found Cox Thimble Drome Super Cub 105 (LDG GEAR) c06u Aircraft - Fuel - Airplanes (FS/W) 0 Jul 10, 2014 07:42 AM
Sold Huge Cub 79" ws (built) OriginalBilly Aircraft - Fuel - Airplanes (FS/W) 4 Jan 25, 2014 11:54 PM
Off Site Sig 71" WS J-3 Cub sunderll Aircraft - Electric - Power Systems (FS/W) 1 Dec 04, 2013 10:47 PM
What would it take to make this Cub a nice EP flyer? gotime242 Power Systems 16 Dec 13, 2005 02:00 AM
What the nicest, most-scale j-3 cub kit under 60" ws gotime242 Electric Plane Talk 8 Aug 01, 2005 12:20 AM
