Old May 14, 2014, 08:11 AM
"I landed it"
MEGAjig's Avatar
Canada, ON, Caledon
Joined Mar 2013
New Glider from HobbyKing - BFG 1600 and 2600
New EPO Gliders
BFG 1600 and 2600 Overview
BFG 1600 and 2600 Flight footage
The BFG 1600 is a 1.6 meter electric glider designed for fun. The all EPO airframe is extremely tough, perfect for flying at those less than perfect slope sites where landing can be an issue. Flying from the slope isn't a requirement since the BFG 1600 has two power options, a motor in the nose with a folding propeller, or a pylon mounted motor with standard propeller. If powered flight isn't your thing, slip on the magnetically secured nose cone and run as a pure sailplane. With its light weight, the BFG 1600 will find those small thermals and keep you entertained for hours.
We've designed the BFG 1600 with optional flaps if you want that option. With the included hardware, and adding two of your own 9g servos, adding them is a breeze. Assembly and transport of the BFG is quite easy thanks in part to the two piece plug-in wings, and bolt on horizontal tail. Since the model is plug and fly right out of the box, all you need to do is some basic final assembly, program your radio and fly!
Features:
Plug and Fly - Just add your choice of TX/RX and battery, minimal assembly and fly!
Ultra tough molded EPO foam airframe
Powerful 2208 1300kv Outrunner motor and folding propeller
Optional flaps
Three configurations - motor in nose, pylon mounted motor, pure sailplane
Mono-wheel landing gear
Specs:
Wingspan: 1600mm
Length: 930mm
Flying Weight: 650g
Wing Area: 24dm2
Motor: A2208-1300kv
ESC: 20A w/BEC
Servo: 9g x 4
Requires:
4+ channel Transmitter and Receiver
3S 11.1V 1100~1300mAh Lipoly Battery
2 x 9g servos if adding flaps
The BFG 2600 is a 2.6 meter electric glider designed for fun. The all EPO airframe is extremely tough, perfect for flying at those less than perfect slope sites where landing can be an issue. Flying from the slope isn't a requirement since the BFG 2600 has a powerful 3720 Outrunner motor in the nose. Powered by a small 4S 14.8V 2500mAh Lipoly battery, the BFG climbs to altitude quickly where the propeller folds back upon throttling down for extended soaring sessions.
Drop the flaps and the BFG really slows down, which is very useful when bringing it in for short field landings. Assembly and transport of the BFG is quite easy thanks in part to the two piece plug-in wings, and bolt on horizontal tail. Since the model is plug and fly right out of the box, all you need to do is some basica final assembly, program your radio and fly!
Features:
Powerful 3720 Outrunner motor and 13.5x7 folding propeller
Large, effective flaps slow down the BFG 2600
Large fuselage access hatch for checking electronics or swapping batteries
Specs:
Wingspan: 2600mm
Length: 1500mm
Flying Weight: 1900g
Wing Area: 55dm2
Motor: 3720 700kv
ESC: 60A w/BEC
Servo: 9g x 6
Requires:
6+ channel Transmitter and Receiver
4S 14.8V 2500mAh Lipoly Battery
At roughly $90 PNF for the 1600 BFG I would opt for a Phoenix 1600 ARF for around $45. There is nothing that can take abuse like the plastic fuse of the Phoenix.
The 2600 is listed for roughly $200 PNF. Pretty steep for an EPO glider. Would like to see an ARF version which I'm sure will come soon.
Thoughts?
MEGAjig is offline Find More Posts by MEGAjig
Old May 14, 2014, 10:48 AM
Arcee Moron
Justapoke's Avatar
The Netherlands
Joined Jun 2012
Nice gliders. The BFG 2600 is the exact same as the Robbe Arcus Sport 2.6 and the ArtTech Diamond 2500. I have the Arcus Sport and it flys great. Don't think there will be a ARF version, as both others also come as BNF.
Oops (0 min 33 sec)
Justapoke is offline Find More Posts by Justapoke
Old May 14, 2014, 12:43 PM
"I landed it"
MEGAjig's Avatar
Canada, ON, Caledon
Joined Mar 2013
Thanks for the info. Do you think / know if the parts used inside the HK version are the same as the Robbe Arcus or did they use their own parts?
I love big gliders and if I had the room in my den I'd love a 2.6m bird. The phoenix 2000 is already big for me to handle here.
I'll look into the Arcus some more.
Old May 14, 2014, 01:25 PM
Arcee Moron
Justapoke's Avatar
The Netherlands
Joined Jun 2012
Well the Arcus has a Robbe motor and ESC, for the rest (the complete airframe and servo's etc) it looks like they all come from the same factory.
Robbe motors are know to be good, but the Arcus retailprice is 298,- Euro / $400,- US
It does take up a lot of space for storage, comes in a HUGE box.
Large Diamond 2500 thread can be found here: http://www.rcgroups.com/forums/showthread.php?t=1134216
And here's another video with the Arcus:
Robbe Arcus Sport 2.6 Fly-By's and Cruising (7 min 14 sec)
Old May 14, 2014, 03:42 PM
USA: LakeGeorge, New York
USA
Joined May 2010
I like the 1600mm version with the shoulder mounted prop (motor pod).
Can Probably take the nose motor out and put a larger 3s Lipo (1800mah).
rclab1 is offline Find More Posts by rclab1
Old May 14, 2014, 06:42 PM
Australia, VIC, Bendigo
Joined Jan 2012
I just read the HK info on it and its not clear if it has two motors...one in pod and one in nose or how power gets from pod to ESC
agedflier is online now Find More Posts by agedflier
Old May 14, 2014, 08:00 PM
justy g's Avatar
Hong Kong
Joined Jan 2007
Interesting new gliders..some of the flight testing done at Clear Water Bay HK
justy g is offline Find More Posts by justy g
Old May 15, 2014, 06:16 AM
Planes, need more planes
flyguide7's Avatar
United States, MO, Chesterfield
Joined Feb 2006
I ordered the 2600 last night. Thinking about installing FPV gear in it. Nice looking plane.
flyguide7 is offline Find More Posts by flyguide7
Old May 15, 2014, 06:28 AM
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
[QUOTE=MEGAjig;28368748]New EPO Gliders
[URL="https://www.youtube.com/watc...........[/QUOTE]Can I put in a friendly request for a change of thread title please? This title is VERY similar to a thread here about the Phoenix 2000. Also, in a few years time this won't be "new" anymore...
Woodstock 1 is offline Find More Posts by Woodstock 1
Old May 15, 2014, 01:06 PM
Joined Apr 2013
Ordered.
Inside area of nose looks huge.
Gonna build this into an FPV glider. Have been using a motionrc Vroc for afPV duty and have limited room with cog issues.
Should be able to get much of the gear into the front and get decent rx and video tx seperation.
This will be my last foamy glider before I jump to a fiberglass/balsa 3meter build.
uglygun is offline Find More Posts by uglygun
Old May 15, 2014, 01:39 PM
Arcee Moron
Justapoke's Avatar
The Netherlands
Joined Jun 2012
Originally Posted by uglygun View Post
Ordered.
It is. Here's a pic of mine with a large 3300 3S, still plenty of space around it.
You could use the whole platform for electronics and put a lipo on top. The canopy itself is also huge and has plenty of space for equipement.
B.t.w. this thread should at least be splitted, it's not a good idea to have both the 1600 and 2600 models in one place.
Old May 15, 2014, 08:13 PM
United States, CA, Pleasanton
Joined Apr 2002
Guys..
A quick question about suitable batteries for the BFG 2600...
This glider includes a 700KV motor.
How do you think it will perform with a high C rated 3s pack as opposed to a 4s pack.
I have plenty of high quality 3300mAh 3s 40C batteries I'd like to try to use with this glider.
TIA for any thoughts.
:harry
harrye is offline Find More Posts by harrye
Old May 16, 2014, 02:37 AM
harborflyer's Avatar
United States, CA, Santa Ana
Joined Jul 2010
WATCHING,
Ross
harborflyer is online now Find More Posts by harborflyer
Old May 17, 2014, 04:15 AM
Australia, QLD, Beaudesert
Joined Jul 2008
This looks like a good glider at what appears to be a good price. I am looking for an e-glider foanie fo step up to somthing bigger, does a foamie glide / thermal ok??
Neal
neale is offline Find More Posts by neale
Old May 17, 2014, 03:40 PM
United States, CA, Altadena
Joined Sep 2013
Neal
Depends on what you expect out of "ok", but a typical sport foamie can ride thermals for as long as your talent can keep them cored. No promises if you fall out of the thermal though.
Pretext is offline Find More Posts by Pretext
Discussion New Glider from HobbyKING-Phoenix 2000 rclab1 Electric Sailplanes 6526 Yesterday 08:46 PM
Discussion Hobbyking ASK-21 2600 mm fiberglass glider: ecworks Scale Sailplanes 20 May 17, 2014 10:06 PM
Discussion Joysway Freeman 1600 Glider morejosh Foamies (Kits) 10 Mar 23, 2014 12:46 AM
Discussion Hobbyking ASK-21 2600 mm fiberglass glider FPV project: ecworks FPV Talk 0 Jun 09, 2013 10:30 AM
Discussion New Speedy 1600 from Aero-Fever Bluenose Slope 1 Mar 30, 2011 02:59 AM
