Old Apr 08, 2013, 05:48 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Build Log
Aeromarine Avenger 36
Look familiar Ray?
I actually got this last week but didn't post photos at the time because I was planning a "secret project" but times and moods change. Should I wait 6 to 10 weeks for a 2215/1Y or choose an alternative power method?
4/4/13: My new Avenger cat arrived from Kintec Racing. The box it came in didnít look too great so wonít bother with any pix of it. (It got wet coming off the UPS truck as we were having a really hard rain at the time and it basically turned one side of it into goo). The hull itself looks great though, no shipping damage.
Weight fresh out of the box came in at 5 lbs 10 oz. with hull hatch and the assorted pieces of tape holding down the hatch and protecting the sponson bottoms.
The monster sized hatch makes one think of dropping a small block Chevy in it but we all know thatís not going to happen. And with it lifted you can see itís all good quality glasswork inside
Remy sure seems to know what heís doing when it comes to making cats. My old Sprintcat .40 has been probably the best handling boat in my fleet and this is just a slightly larger and much better looking version of it. The Avenger measures a fill 36Ē from front to rear on the top half. The lower is 35.5Ē from sponson transom to sponson tip. The Spintcat although advertised at 36Ē is in reality only about 34.25Ē The Avenger has a slightly wider beam as well measuring in at 14.5Ē compared to 14Ē on the Sprintcat.
Since all I have at the moment is the hull thatís about as far as itís going to get for a while. Iíd like to put a Neu 2215/1Y 1440 kv motor in it as a single but havenít ruled out a pair of HET 700-83 1445 kv motors in it.
If I were just playing around Iíd for sure go with the twin setup but not sure the allotted 10,000 ma max battery capacity would last for a 4 minute heat of Q offshore. With a single I could run two 6s 5000ís in parallel for 10,000 ma total where if I run twins itís only going to allow 5000 ma per motor.
bill34207 is offline Find More Posts by bill34207
Old Apr 08, 2013, 06:22 PM
RayR's Avatar
United States, FL
Joined Aug 2006
Heck, you already have a great running Q. I would wait and put the 2215 in it.
RayR is online now Find More Posts by RayR
Old Apr 08, 2013, 06:34 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I'm glad you came along and found this Ray. What did you use to build up the hull transom to match the lid on yours?
I'd kind of like to have this one built before the Waveblasters race but at the same time I'd like to try out a 2215. I think the 1440 kv would be a good one for Q.
Old Apr 09, 2013, 02:56 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Hi bill another sweet build on the table LOL
Just 1 thing check to see if they have taped the join have seen a few aeromarine hulls pull apart cos they dont tape the seams unless you ask them to ,they should just do it to all the there hulls
iv got 1 of there hydros and iv got to do the same on that
F1 madness is online now Find More Posts by F1 madness
Old Apr 09, 2013, 03:21 AM
RayR's Avatar
United States, FL
Joined Aug 2006
Bill,
I used some G-10 I had floating around to build out for the rudder placement. I can bring some if you need it. The 1440kv is just about perfect for Q, I also seriously considered the 2215, but used the 1527 I already owned.
Old Apr 09, 2013, 04:34 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Thanks for the tip on the seams Daz. I'll check that and at least do a partial tape if it isn't already there.
Originally Posted by RayR View Post
Bill,
If you have a spare piece of G10 bring it out when we run again. It would be greatly appreciated. I was getting ready to order some 2mm CF plate and laminate something to use. I measured it with the depth bar on my caliper and it will have to built up 4mm to match the top.
If Steve had the 2215's in stock I'd already have one coming this way but haven't pulled the trigger on having him special order me one yet. Starting to think about the 1530/1.5D. It's a 1355 kv motor and by the Neumotors chart is rated the same as the 2215 for continuous and peak watts. (He has one of them in stock too)
http://neumotors.com/Site/1500_series.html
http://neumotors.com/Site/2200_12_series.html
Old Apr 09, 2013, 05:58 AM
RayR's Avatar
United States, FL
Joined Aug 2006
I wouldn't choose a "D" wind for distance running, but that's just me.
Old Apr 09, 2013, 08:00 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
My thoughts as well Ray. That was my biggest concern with going that route.
Starting to think I'll have Steve order the 2215 and put my old 1717 in it to play with until the Neu arrives. I'll set it up for 4" rail mounts and then can fit pretty much anything in it. Already checked South River and he has mounts for both the 2215 and 1717 available for 4" rails.
Old Apr 09, 2013, 04:45 PM
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
Bill,
I have a sheet of G10 that your welcome to use if it will serve your purposes. Let me know and and I'll drop it off on my way home tomorrow.
osprey21 is offline Find More Posts by osprey21
Old Apr 09, 2013, 06:35 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Thanks Chris. No big rush though unless you just want to drop by.
I may be working on this one for a while. (mostly waiting on stuff to arrive). I haven't even ordered a strut & rudder for it yet, but did pull the trigger for the 2215 with OSE today. It's paid for, now I just have to wait for it to be built.
Old Apr 10, 2013, 02:16 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
No probs Bill
just a heads up thats all
ill keep an eye on the build see how you getting on
Old Apr 10, 2013, 05:45 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I finally took the hatch back off and took a look at the seams Daz. It came with them pre taped as far down the sponsons as I could see. The carbon inlay in the rear portion actually comes up past the seam lines as well.
The 1st piece of build hardware arrived today. I ordered the 240 Ice from Tower last week. (good old super saver discount coupon that dropped it from 339.00 to 289.00 with free shipping). It showed up at work today and when I got home found a big square of G10 tucked in behind my mailbox. Thanks Chris.
I'm going to eventually have to start working on actually building this one.
Old Apr 10, 2013, 08:04 PM
United States, FL, Bradenton
Joined May 2012
Hey Bill, nice
I think I know where you can get a jacket for the 2215. Did you order the fin motor?
Dave
HRCMFG is offline Find More Posts by HRCMFG
Old Apr 11, 2013, 04:09 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Thanks Dave. I was planning to talk to you Sunday and have you mark one of those jackets for me. It will be a while before I actually need it but knew where to look for one. I was thinking about some of those nice aluminum rails you make too.
Old Apr 11, 2013, 11:17 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Cool glad its ok then bud
wished they off done it on my hydro and a friends hydro and conquest both off his pulled apart
For Sale 36" aeromarine fast electric brushless boat with leopard 5698 and all hardware, flex jmscard Boats (FS/W) 0 Feb 13, 2013 12:53 AM
For Sale Aeromarine Team Believer 36" Fast Electric Brushless Cat ARTR jmscard Boats (FS/W) 1 Feb 13, 2013 12:42 AM
For Sale Aeromarine 36" Sprintcat jstickley Boats (FS/W) 0 Jun 16, 2011 09:01 PM
For Sale aeromarine team beleiver 36" nitro and nitro ld3 blastfrmdapast Non R/C Items (FS/W) 0 Jul 14, 2010 12:12 AM
For Sale Aeromarine 44" Avenger Hull getbig33 Boats (FS/W) 7 Mar 12, 2009 07:41 PM
