Old Feb 17, 2003, 05:32 PM
roguewolf is offline
Find More Posts by roguewolf
MEDIC!!!!!!!
roguewolf's Avatar
Near Fresno, California
Joined Sep 2002
Spanked my E-starter
Well, I started building this brick at 6am and was finished by noon.
Admitedly, I'm using a 7cell HE pack; however, by the time I was done AUW was 17.05 ounces.
I hadn't finished with the visual trim job, but I had to go fly the thing.
I have to admit that I've only flown R/C with a slowstick and didn't consider that I would need 50+ feet of take off room to get this thing off the ground....this thing is going to force me to get a mini AC brushless...
roguewolf is offline Find More Posts by roguewolf
Old Feb 17, 2003, 05:34 PM
MEDIC!!!!!!!
roguewolf's Avatar
Joined Sep 2002
Another pic premaiden:
Old Feb 17, 2003, 05:36 PM
MEDIC!!!!!!!
roguewolf's Avatar
Joined Sep 2002
Last premaiden:
Old Feb 17, 2003, 05:38 PM
MEDIC!!!!!!!
roguewolf's Avatar
Joined Sep 2002
Then I ran out of runway at the edge of the infield and hit the grass,.......ripping the landing gear out of the fuse....
Old Feb 17, 2003, 05:42 PM
MEDIC!!!!!!!
roguewolf's Avatar
Joined Sep 2002
Then like a complete dork, thought I would go ahead and fly it w/o the gear....completely forgeting about the HUGE change in CG it would cause by leaving the lg off......resulting in.......
Old Feb 17, 2003, 05:44 PM
MEDIC!!!!!!!
roguewolf's Avatar
Joined Sep 2002
And.....
Old Feb 17, 2003, 05:47 PM
MEDIC!!!!!!!
roguewolf's Avatar
Joined Sep 2002
All repairable considering that it came in nose first like a brick from 25-30 feet up....have to do something about the lg though....stuffed all the gear I had borrowed from the SS back on and had a good day flying anyway.....
Old Feb 17, 2003, 06:01 PM
10Thumbs is offline
Find More Posts by 10Thumbs
Motor Maniac
Orange County, CA
Joined Feb 2002
Nothing a little PU or epoxy won't fix. Is this stock other than the battery?
I'm surprised you were able to get up to 25' if the CG was way off. With all that weight and tail heavy the wing was probably near stall the entire time. Ailerons are a whole new ballgame when you are used to flying R/E only.
10Thumbs is offline Find More Posts by 10Thumbs
Old Feb 17, 2003, 06:16 PM
MEDIC!!!!!!!
roguewolf's Avatar
Joined Sep 2002
Strong hand launch at full throttle gets it up there....and then noses in.......A little epoxy goes a long way...not a problem... would fly it again this afternoon if I hadn't worn the transmitter battery down to 20% on the slowstick...the only other non-stock is the 9x7-3 blade prop...Motocalc says same thrust at a lower motor temp...
My E-Starter build fizzak Parkflyers 1 Oct 09, 2003 02:10 PM
Good bye my E-Starter temp_oct Parkflyers 30 Oct 06, 2003 07:58 AM
Fallen Angel..... RETRIEVED my E-Starter today temp_oct Parkflyers 7 Sep 25, 2003 05:05 AM
E-tec 1200-2S for my E-starter? nikko Parkflyers 9 Aug 13, 2003 07:40 PM
My E-Starter is HOT, no, REALLY HOT! Foam Crazy Parkflyers 20 Aug 13, 2003 12:22 AM
