Old Mar 24, 2015, 09:10 AM
Rotorfreak is offline
Find More Posts by Rotorfreak
Canada, QC, Montreal
Joined Jan 2006
EDF surge
I have an HK Mercury Alloy 1600 (8S) EDF, powered by two (2) 4S (65-130amps) 5000 mah batteries in series, controlled by a Turnigy dlux 120a ESC.
I did some bench testing and found the EDF to be surging slightly at full throttle. Any ideas as to what may be the cause?
BTW, didn't have any fashion of measuring RPM nor did I measure any current parameters during the test.
I was more curious about lbs thrust developed than anything else. Any opinions would be appreciated. Thanks in advance for anyone's opinion.
Rotorfreak is offline Find More Posts by Rotorfreak
Old Mar 24, 2015, 09:16 AM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Try changing the low voltage cutoff setting on the ESC to do nothing, rather than reduce power. It might be your batteries not maintaining voltage under load (causing the ESC to hit LVC).
Hook up a simple LIPO battery monitor on your balance leads during the run to see what your cell voltage is doing under load.
4stripes is online now Find More Posts by 4stripes
Old Mar 24, 2015, 10:20 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Yea sounds like low volts. you need to put a meter on it and read volts under load. Check the esc settings. May be set for wrong cell count
Old Mar 25, 2015, 06:18 AM
Joined Jan 2006
Thanks very much for your opinions. They sound good and will check things tonight. I will follow-up.
Old Mar 25, 2015, 08:30 AM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Check your lipos as they may not be standing up to demands.
Madmax1965 is offline Find More Posts by Madmax1965
Old Mar 30, 2015, 04:17 PM
Joined Jan 2006
Hi guys, sorry for the delayed reply. Found the ESC set for 10 cell count and set it to 8
since that's what I'm running (2-Packs of 4 cells in series). I also set the undervoltage to "ignore". Not sure if I should have done that? Anyway, when I tested it this time she was a screamer and no surging at all! Thanks very much for your help! Do you think I should set the undervoltage to "Reduce Power" or leave it as is?
Old Mar 30, 2015, 04:51 PM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
Set the LVC (Low Voltage Cutoff) to 3.2V. And try it again with LVC set to reduce power. Never set LVC to cut off power. Batteries are less then new jets.
rfodor is offline Find More Posts by rfodor
Old Mar 30, 2015, 06:25 PM
Joined Jan 2006
Will do as suggested! Thank you!
Old Mar 31, 2015, 06:40 AM
4stripes's Avatar
Joined Jan 2009
I would set to do nothing (ignore)) as a power reduction may cost you your model. Better to use a battery voltage monitor and time your flights to keep voltage safe.
Old Mar 31, 2015, 03:39 PM
Joined Jan 2006
I like your suggestion also, and would prefer to do that as I have a timer on my Taranis. Thanks 4 stripes and everyone for your help!
Old Mar 31, 2015, 09:46 PM
Mark Powell is offline
Find More Posts by Mark Powell
United Kingdom, England, Southampton
Joined Oct 2013
Mark Powell is offline Find More Posts by Mark Powell
Last edited by Mark Powell; Mar 31, 2015 at 09:48 PM. Reason: I noticed he had sorted it so doesn't need any more help
Reply With Quote  (Disabled)
Discussion Power surge with ESCs allahjane Power Systems 5 Sep 25, 2013 07:03 AM
Discussion Surge crusher broken shaft..... kosmas Racing Boats - Electric 0 Sep 22, 2013 01:13 PM
Discussion Surge - What is Surge RC? Nik SurgeRC Electric Plane Talk 0 Jun 24, 2011 04:44 AM
Question Surge-pause-surge-pause - Ouch! Mickmeister Micro Helis 6 Oct 14, 2010 05:33 AM
For Sale Carl Goldberg modified Surge 400 aka Re-Surge MustangAce17 Aircraft - Electric - Airplanes (FS/W) 3 Dec 24, 2008 08:28 PM
