Old Jul 12, 2013, 06:09 PM
hobbypartz is offline
Find More Posts by hobbypartz
hobbypartz's Avatar
Los Angeles
Joined Mar 2009
Super nice 350 watt power supply 23 AMPS!!!
Thunder T350 350watt 23Amp Power Supply (3 min 28 sec)
The Thunder T350 is a powerful AC to DC switching power supply. This full featured power supply out-puts up to 15V 350 Watt DC power. Boasting enough power to sufficiently supply current to a large capacity battery charger. The T350 also features a variety of safety features including low voltage input, over-current, over-temperature and short-circuit protection. The T350 is constructed with an all aluminum case and has a built in fan controlled by an internal temperature monitor. The low power consumption, built in EMI filter and AC100-240V capability allows this efficient power supply to be used anywhere. Utilize this compact power supply on your workshop bench or on the go.
Features:
Active PFC (Power Factor Correction)
Portable small size
Attractive aluminum case
Built in temperature controlled fan
Over current protection
Overheat protection
Short circuit protection
AC100-240V worldwide use
Low power consumption
Built in EMI filter
Specifications:
Input Voltage Range: 100-240Volts AC
Output Voltage Range: 15-15.5Volts DC
Input Frequency: 50/60Hz
Output Current: 0-23Amps
Power: 350 Watts
Efficiency: 88%
Get it here at Hobbypartz for $59 as of 7/12/13 (free shipping over $100 purchase within the USA)
hobbypartz is offline Find More Posts by hobbypartz
Discussion Pro Tek Super Pro 2000 watt Power Supply dstewart51 Batteries and Chargers 0 Apr 23, 2013 04:11 PM
Sold 57 amp 12 volt 684 watt power supply for charger***59.95 Shipped**** Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 29, 2013 06:33 PM
For Sale New Gecko G540 Rev 8 3 Nema 23 300oz 48V 7.3A power Supply 20Ft Cable & E-stop $1 Aurora9 Aircraft - General - Miscellaneous (FS/W) 0 Mar 06, 2013 01:53 PM
Sold 350 watt/29 amp Power Supply.. Tram Aircraft - Electric - Batteries & Chargers (FS/W) 3 May 22, 2009 11:35 PM
New Product New - Just Released - 29 Amp, 350 Watt AC/DC Power Supply for only $69.95! RcSuperSales-Net Electric Heli Talk 13 Oct 29, 2008 10:12 PM
