Old Feb 15, 2015, 07:19 PM
FireHawx is offline
Find More Posts by FireHawx
FireHawx
FireHawx's Avatar
United States, NV, Reno
Joined Oct 2011
It seems these 8blade 70mm are the new thing? How do they sound?
FireHawx is offline Find More Posts by FireHawx
Old Feb 15, 2015, 09:21 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
funny u beat me to the same question.................... very interested in that one.
chas650r is offline Find More Posts by chas650r
Old Feb 15, 2015, 09:26 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
Originally Posted by bps View Post
I have a small collection of 70mm fans and decided to do some primitive testing to compare the ones I have. Here are the fans I tested;
Change Sun 12B with Turnigy 2855-2800 630 watt motor found here http://www.hobbyking.com/hobbyking/s...ner_630w_.html
3S 33 amps and 380 watts
4S 45 amps and 627 watts
FMS 70mm 8B fan and 2845-3000 found here
http://www.motionrc.com/fms-f-4-phan...p/#spare-parts
3S 40 amps and 440 watts
4S 52 amps and 675 watts
Eflight Delta V-15 5B and BL15-3600 motor found here
http://www.horizonhobby.com/airplane...ed-fan-efldf15
3S 27 amps and 305 watts
4S 41 amps and 614 watts
Batteries used were Turnigy Nano Tec 2.65A 3S and 2.2A 4S rated at 25-50c
These tests were rather crude without any kind of ducting or any intake rings. All it does is to compare the 3 fan units under similar conditions. Just thought some might be interested in these numbers. I would love to have some thrust figures to share but I do not have the capability yet.
problem is w/o the intake ring each fan reacts differently so the comparison may be skewed . really need the ring on there.
Old Feb 15, 2015, 09:28 PM
bps is online now
bps
Find More Posts by bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
The 8b has less of a jet sound than the 10 or 12b but much quieter than the 5bs are.
bps is online now Find More Posts by bps
Old Feb 16, 2015, 12:02 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
it is not actually about how many blades, it is the "Blade to gap Ratio" that makes the sound difference. A "low" blade to gap ratio - like where a blade is equal to the gap between them for eg. - does not give the 'solid wall of air whoosh'.
4,5,6 blades, and Wemo EVO 9 blade, are all low blade to gap ratio. And I expect the FW 8bl is also.
Note there are now 10,12,13,14 blade 70mm fans with 'high' blade to gap ratios now. All these types are more in the region of 95%+ blade, to the 5% gap. All are CS (Changesun).... or renamed/made for XRP....
PeterVRC is online now Find More Posts by PeterVRC
Old Feb 16, 2015, 03:43 AM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
the new 8- bladers...
+1
8 blades seem to come into fashion, witness the HSD 75mm Viperjet, very good performance it seems, judging from the RC Informer videos etc., and pretty good sound
wouldn't mind it if they are a bit more efficient than the Change Suns (and, possibly, cope with less ideal circumstances in the ducting, and some FSA reduction in the exhaust.
haven't seen the 8-blade on sale anywhere except motion rc, shipping to Europe would be way too expensive, if I can get it in Europe or at a fair price incl shipping via Asia I'll give it a try...
EDIT: interesting what Motion RC writes: as of 9/2014 it should come with the V2 Alphajet (and F4 Phantoms) of FMS, but checking the description of the Alpha Jet at Motion, there is still the 10-blader mentioned. I remember thinking that 3000kV on 4s for a 10-blader is quite a lot, and certaiinly too much for a 2200mA lipo - and possibly for the motor if the lipo can deliver. So FMS had a problem at hand, and they apparently solved it with this 8-blade fan (lower load compared to the 10-blader). They could also have gone with a 2500kV motor - maybe the 8-blader has some other benefits?
hey, there's an alloy 8-blade 70mm rotor at HK (that's the one I would like - in plastic...)
http://www.hobbyking.com/hobbyking/s...Fan_Rotor.html
mopetista is offline Find More Posts by mopetista
Old Feb 17, 2015, 10:48 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
The description says they changed from 10 to 8 blade in order to gain extra battery life.
For the life of me none of these guys are into the science of fluid dynamics when it comes to EDFs...
.... instead of changing the horrible ducting (mostly made for 5 blade and 7 blade rotors) in these jets they just change the rotors and think the efflux and or the static thrust will increase.... or the energy in will decrease...
The total energy out (static thrust and efflux relative to bench numbers) on the multi bade fans (10 - 14 blade) coupled with the CORRECT ducting AND plane design yields results just as good as the 5 - 7 blade rotors....
Rainer said it best about a couple of weeks ago...
Most if not all the ducting in our CURRENT edfs models seem to be made for 4 - 7 blade fans (sic)...
erh7771 is online now Find More Posts by erh7771
Old Mar 25, 2015, 04:55 AM
bps is online now
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
I am currently looking at better EDFs for the Me262. In reading through this thread looks like a inexpensive set up might be the CS12b with Turnigy 2855-2300 on 4s. At under 50 amps if I am reading this correctly sounds good. Inputs?
http://www.hobbyking.com/hobbyking/s...dProduct=71747
Old Mar 25, 2015, 05:03 AM
bps is online now
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Found this on e-bay. Has anyone tested this fan?
http://www.ebay.com/itm/70mm-Ducted-...tem418475aeb4#
70mm Ducted Fan Set 12 Blades EDF With Electric Motor kv2600 all Tested Balance
Specification:
Rotor Diameter:70mm
Outer Diameter:75mm
Weight:180 g
Propeller:12 Blade Propeller
Apply to Battery:3s-4s
Apply to ESC:60A
Motor:Brushless Motor 2839 2600kv
Maximum Current: 35-49A
Thrust: 1.1-1.4kg
Old Mar 25, 2015, 05:23 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
I 've used the 2855-2300kv on the 10Blade extensively on both 4S and 5S.
I believe it would also work well on 4S only for the 12B.
anlucas is online now Find More Posts by anlucas
Old Mar 25, 2015, 05:25 AM
anlucas's Avatar
Joined May 2011
Specification:
Rotor Diameter:70mm
Outer Diameter:75mm
Weight:180 g
Apply to ESC:60A
Thrust: 1.1-1.4kg
First time I've seen this one. Doesn't seem to be a ChangeSun or XRP.
This is probably a better choice.
http://www.x-flight.com.hk/index.php...&more=&lang=en
Old Mar 25, 2015, 05:32 AM
ukbren is offline
Find More Posts by ukbren
ukbren's Avatar
United Kingdom, Derbyshire
Joined Aug 2011
from what i've read, around 3000kv seems to be the general order of the day on 4S, so you might be better off with the 2800kv version (that's what i use on my 4S-powered freewing F16) - i suppose it might depend how draggy the airframe is?
ukbren is offline Find More Posts by ukbren
Old Mar 25, 2015, 06:21 AM
bps is online now
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Thanks for the input. I want to keep the amp draw as close to 100 amps as possible Pipe Dream??
Old Mar 25, 2015, 06:30 AM
bps is online now
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
That looks good at only 56 amps. Thanks
Old Mar 25, 2015, 10:00 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
the kv must vary a lot on the h/k 2300........... mine even w/ a very good low ir battery would only draw 40 amps on 4's . thrust was to low for the weight of the system , seems a better setup for 5's. 2600-2800 kv has worked better for me .
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 193 Feb 24, 2015 12:34 PM
Discussion Change Sun 70mm 10 blade EDF SpaceAviation Electric Plane Talk 8 Jan 22, 2013 04:06 AM
For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN rlc2052 Aircraft - Electric - Jets (FS/W) 1 Nov 01, 2012 02:24 PM
Sold Change Sun 70mm 10 Blade EDF TreeFlyer Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 03:50 PM
Sold New Change Sun 70mm 10 blade fan. TreeFlyer Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 05:59 PM
