Old Dec 18, 2015, 01:20 PM
bredler is offline
Find More Posts by bredler
United States, PA, Pitts
Joined Jan 2015
Question
Removable Stab Designs
I'm gearing all of my stuff up right now to build my Oly III from Skybench. I'm looking at the tail group and thinking that it would be nice to have it removable. I've seen several designs and there's quite a bit of variation. I have a few questions:
  1. Are the vertical and horizontal stabs typically independent or is that just inviting poor alignment and weak joinery? It would save a lot of space for storage if they were separate.
  2. What additional structural elements should I incorporate to make the removable stab?
  3. Can you please post some pics or a link to a post of your own removable tail setup?
Thanks!
Brendan
bredler is offline Find More Posts by bredler
Last edited by bredler; Dec 18, 2015 at 01:35 PM. Reason: Changed type of post to 'Question'
Old Dec 18, 2015, 08:58 PM
Pauliwog is offline
Find More Posts by Pauliwog
United States, OR, Corvallis
Joined Jan 2010
My 2 Cents on Removable Tail feathers....
http://www.rcgroups.com/forums/showthread.php?t=1529033 Very Modified GP Spirit 2M Woody, Page 8
http://www.rcgroups.com/forums/showthread.php?t=1408867 Guillows Arrow rubber powered freeflight conversion to a 2ch RC glider, page 2.
http://www.rcgroups.com/forums/showthread.php?t=1953676 Goldfinch scratch build scratch design, pages 2,3 & 4
Hopefully this works and you'll be able to see these build logs I've posted over the years. You may have to dig through the build logs but each one will have a removable set of tail feathers. I also have build logs posted on an Ace RC Easy Eagle with a bunch Mods and House of Balsa "2x4" with removable tail pieces but they seem to have faded away from the archives over time, but the build logs I have posted here have better methods and final results anyway.
I really like having removable tail feathers for storage, transport, and ease of repair reasons. I also do most of my flying-by-bike(everything loaded in and on my backpack and bike to the flying sites). I see no reason not to have removable tail feathers, especially on larger gliders.
Good Luck - Paul
Pauliwog is offline Find More Posts by Pauliwog
Old Dec 18, 2015, 10:23 PM
buzzfly is online now
Find More Posts by buzzfly
buzzfly's Avatar
Joined Apr 2003
I seem to recall (perhaps incorrectly) that Ray offered a removable tail option on the Oly III.
I have an Oly III a friend built with a fixed tail. A removable tail would add greatly to its transportability and storage. Check with Ray to see what he says about it. Perhaps he can send you parts and plan updates easily!
buzzfly is online now Find More Posts by buzzfly
Old Dec 19, 2015, 03:24 AM
ZAGNUT is online now
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
making the fin a permanent part of the fuselage goes a long way in keeping things straight and stiff but it needs to be built as part of the structure and not just glued on top. will still make storage and transportation a breeze compared to permanent stabs.
look at plans on outerzone to see the various methods. the sagittas come to mind.
ZAGNUT is online now Find More Posts by ZAGNUT
Old Dec 19, 2015, 12:00 PM
jetmaven is online now
Find More Posts by jetmaven
If you go to outerzone take a look at the Aquila as well , fixed verticle , removable stab halves .
Been flying the same one since the 70's , never had a problem .
jetmaven is online now Find More Posts by jetmaven
Old Dec 19, 2015, 10:16 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
I had an Oly 650 where I put tapped holes in the stab and put nylon screws passing through the fuselage and screwing into the stab. Or maybe just one screw. I left the horizontal and vertical stabs as one unit. A bit bulky, I suppose, but it worked.
lincoln is offline Find More Posts by lincoln
Old Dec 23, 2015, 06:34 AM
whacker is online now
Find More Posts by whacker
whacker's Avatar
Canada, NS, Tatamagouche
Joined May 2005
Here's what I have done on a number of occasions
A lot of little pieces, but mechanically solid
whacker
whacker is online now Find More Posts by whacker
Old Dec 28, 2015, 08:09 AM
ultimatetwo is offline
Find More Posts by ultimatetwo
Fly to live- Live to fly
ultimatetwo's Avatar
ROTA-CADIZ-SPAIN
Well done...กกกกก
ultimatetwo is offline Find More Posts by ultimatetwo
Discussion Byron F16 - Retract & Stab Linkage Design Ideas Mark_ASP Large EDF Jets 21 Dec 11, 2013 06:01 PM
News Revolution Design Ultra Exhaust Spring Remover Paul Onorato Car Talk 0 Nov 15, 2013 08:41 AM
Discussion Kulbutin crazy AMT rebuild & update - MadStuff ! - removable Mad-Stab design Phil.Taylor Slope 47 Jun 15, 2013 05:56 PM
Freedom 3D removable horizontal stab Parahawk Sport Planes 3 Apr 05, 2004 10:59 PM
Removable LG and STAB for TINY - Suggestions? fliir Parkflyers 0 Feb 26, 2002 11:13 AM
