Old May 29, 2015, 03:38 PM
cobbie is offline
Find More Posts by cobbie
Joined Apr 2008
Build Log
P51
Here is my P51 it has a few parts missing and has no instructions, so I hope as I ask questions and show pics that the rc builders out there can help
cobbie is offline Find More Posts by cobbie
Old May 29, 2015, 03:42 PM
cobbie is offline
Joined Apr 2008
Here is the hardware I got. I would like to mount the retractablt tail wheel. I would guess that I have to cut out the fuse.
Old May 30, 2015, 04:46 AM
scale_only is offline
Find More Posts by scale_only
on'tday eedfay ethay ollstray
scale_only's Avatar
United States, OH, Avon Lake
Joined Apr 2010
I'm sure we can walk you through it,,
In case you didn't know, that was made by a defunct company called "Giant Scale Planes"
Found a build thread http://www.rcgroups.com/forums/showthread.php?t=1571482
good luck
scale_only is offline Find More Posts by scale_only
Old May 30, 2015, 12:41 PM
cobbie is offline
Joined Apr 2008
Thanks that build thead looks great.
I was looking at my ailorons and flap noticed that the hing line or v on back side is not centered do I make that my pivot point.
Old May 30, 2015, 06:40 PM
scale_only's Avatar
Joined Apr 2010
I'd say Yes, Likely that's how it's designed to work for that model.
Old May 31, 2015, 02:37 PM
cobbie is offline
Joined Apr 2008
I drilledand test fit my Robart hinges in elevators. I drew out where I thought the flaps and ailerons pivot points should be. How many hinges per surface?
Old Jun 01, 2015, 04:27 PM
cobbie is offline
Joined Apr 2008
Ok today I drilled and fitted the flaps and ailorons. couldn't find any grease for hinges so I will pick some up tomarrow and glue all control surfaces.
On another note I'm looking at the DLA 64 inline for a power plant. Any thoughs on them are welcome.
Specs from the other build log say 24lb for plane
Spec for DLA 64 say 30 lb thrust.
Found P51 hanger 9 40 size Wings or 40 or 60 P51 ARF Kit StevenFox950 Aircraft - Fuel - Airplanes (FS/W) 7 May 06, 2015 11:02 AM
For Sale ESM p51, Top Flite p51 ,kit built p40, 3dhs slick*****lowered prices** redrider2 Aircraft - Fuel - Airplanes (FS/W) 9 Dec 07, 2014 12:25 AM
Discussion 1450 mm FMS P51 versus Airfield P51 Copperhead13 Electric Warbirds 4 Jan 21, 2014 02:16 PM
For Sale WTS PZ P47, Durafly F4U and P51, AF F6F, BlitzRC P51, and micro PZ F4U and P51 in W APIT Aircraft - Electric - Airplanes (FS/W) 13 Aug 31, 2012 02:48 PM
Wanted GSP 96" P51 arf, Top Flite GS P51, Byron T6 or P51 Jon Koppisch Aircraft - Fuel - Airplanes (FS/W) 0 Sep 15, 2005 07:25 AM
