Old Apr 18, 2013, 10:01 AM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
New Product
E-Flite J-3 Cub 450 ARF..............
have a soft spot for the old J-3 Cub as the UM J-3 is what started me off
this one looks nice too
The E-flite® J-3 Cub 450 ARF airplane is the perfect scale model for small-field flying or making a quick flight at the local park as satisfying as possible. No other airplane has touched more pilots or better demonstrated that flight itself is an unequivocal expression of freedom than the J-3 Cub. Its practical design not only made it versatile, but more importantly, it made it a pure joy to fly. E-flite captures the Cub spirit in a lightweight all-wood structure that authentically replicates the character and distinctive outline of what the designer envisioned as the airplane for everyone.
From the richness of its traditional construction, to the authentic sheen of its UltraCote® finish and balloon-shape wheels, the E-flite J-3 Cub 450 ARF delivers a great-looking scale model the casual flier to expert scale critic will appreciate. The recommended E-flite power system was designed around popular and economical 3S Li-Po batteries to provide long, lazy flights or one wheel touch and go's.
Key Features
True-to-scale proportions
Laser-cut balsa and plywood construction
Genuine Hangar 9® UltraCote® covering finish
Factory-built airframe with quality hardware package
Ready-to-mount an E-flite® Park 450 or Park 480 motor
Pre-painted fiberglass cowling with accurate engine detail
Cross-brace and instrument panel cockpit detail
Internal servo mounting maintains scale integrity
Pre-cut clear plastic windshield and pre-formed side windows
Authentic Cub wheels and finished wire landing gear
Large magnetic battery hatch
Steerable tailwheel
Needed To Complete
- 4+ channel transmitter and receiver radio system
- Motor
- Speed controller
- Flight battery
- (4) sub-micro servos
- Propeller
- Charger for flight battery
Wingspan: 51.0 in (1300mm)
Overall Length: 32.9 in (835mm)
Wing Area: 374 sq in (24.1 sq dm)
Flying Weight: 33.2-35.5 oz (940-1005 g)
Motor Size: Park 450-480 brushless outrunner
Radio: 4+ channel radio system
Servos: (4) digital sub-micro servos
Trim Scheme Colors: UltraCote Cub Yellow (U884), Black (U874)
CG (center of gravity): 1-3/8 to 1-3/4 in (35-45mm) back from the leading edge of wing
Prop Size: 10 x 7 - 12 x 6
Speed Control : 30-amp brushless
Recommended Battery: 11.1V 3S 1800-2200mAh LiPo
Flaps: No
Retracts: No
Control Throw (Ailerons): Low: 7/16 in (11mm) up, 5/16 in (9mm) down; High: 9/16 in (14mm) up, 1/2 in (12mm) down
Control Throw (Elevator): Low: 5/8 in (15mm) up/down; High: 3/4 in (20mm) up/down
Control Throw (Rudder): Low: 5/8 in (15mm) right/left; High: 3/4 in (20mm) right/left
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Assembly Time: 3-5 Hours
Is Assembly Required: Yes
Video!
http://www.youtube.com/watch?feature...&v=dsQzsIybKt8
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Apr 18, 2013, 10:14 AM
Thrawn150 is offline
Find More Posts by Thrawn150
Thrawn150's Avatar
USA, IL, Oak Lawn
Joined Apr 2007
I like that it is built up. I like Wood planes over foam so i think I may get this.
Thrawn150 is offline Find More Posts by Thrawn150
Old Apr 18, 2013, 10:30 AM
wattman is offline
Find More Posts by wattman
wattman's Avatar
Evansville Dress Reg., Indiana, United States
Joined Jun 2004
Its about time and it really looks good .
I have been wanting them to make a Cub .
NOW , what is the wing loading ?
And is the landing gear attachment area STRONGER than the Champs was/is ?
Because I have seen first hand how weak the Champs fuselage LG area and wire landing gear was , several times
But I am ready to get this Cub myself "IF"
wattman is offline Find More Posts by wattman
Old Apr 18, 2013, 03:10 PM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
It seems really heavy for a Cub.
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Apr 18, 2013, 03:17 PM
aftica is offline
Find More Posts by aftica
Plastic Buddha
aftica's Avatar
Joined Oct 2005
Looks pretty good to me! Wing loading of ~ 12.75-13.65 oz/sq' using their numbers. Should be able to assemble it a bit lighter. I probably give it a try, can never have too many Cubs!
aftica is offline Find More Posts by aftica
Old Apr 18, 2013, 09:32 PM
HuffDaddy is offline
Find More Posts by HuffDaddy
No Guts, No Glory!
HuffDaddy's Avatar
USA, WA, South Hill
Joined Sep 2008
why am I excited to see it but yet sad because no flaps?
not that it would need them, just cool to have onboard (I think)
or at least 'flap ready'
HuffDaddy is offline Find More Posts by HuffDaddy
No Guts, No Glory!
HuffDaddy's Avatar
USA, WA, South Hill
Joined Sep 2008
wonder if there is an easy way to add em? prob not...
Old Apr 18, 2013, 09:48 PM
FrankSteffens is offline
Find More Posts by FrankSteffens
United States, NY, Ronkonkoma
Joined Jun 2012
They probably didn't add them because the real J-3 Cub didn't have them... adding them would also add weight in the form of more servos and hardware.
If the wing loading isn't too bad, and can be flown nice and slow like a Cub should be, it won't need them. In real Cubs, pilots use cross controls to side slip in...which makes the Cub descend rapidly without too much acceleration.
FrankSteffens is offline Find More Posts by FrankSteffens
Old Apr 18, 2013, 09:59 PM
No Guts, No Glory!
HuffDaddy's Avatar
USA, WA, South Hill
Joined Sep 2008
really? sheesh, that shows ya how little I know of the scale J-3 Cub... I coulda sworn they did... I'm thinking that they did probably because I added them to my HZ Super Cubs over the years... something to tinker with
so this one is pretty scale then I suppose
Old Apr 18, 2013, 10:10 PM
Th3UmBrA is offline
Find More Posts by Th3UmBrA
AMA# 980507
Th3UmBrA's Avatar
United States, FL, Loxahatchee
Joined Feb 2011
Piper PA-18 Super Cubs did have flaps...I think the Piper J-3R was the only J-3 variant that had flaps. I could be wrong of course .
I can't wait for this to finally show up at my LHS. I think I may go down there tomorrow after work and preorder one. I already have all the rest of the components so why not .
Th3UmBrA is offline Find More Posts by Th3UmBrA
Old Apr 18, 2013, 10:42 PM
Eclipse_7's Avatar
Joined Nov 2003
Whoa! The price tag on this one is $170!
That would be what it would cost to get one of Pat's 1:8 scale planes RTF. And they would weigh half as much!
Old Apr 19, 2013, 02:46 AM
sj3cub is offline
Find More Posts by sj3cub
North Carolina
Joined Sep 2003
Yea, The wing loading looks a little high to me for a 51 inch J3?
sj3cub is offline Find More Posts by sj3cub
Old Apr 21, 2013, 03:03 PM
JazzMan2001 is offline
Find More Posts by JazzMan2001
JazzMan2001's Avatar
Hampshire, United Kingdom
Joined May 2009
This one looks really tempting
JazzMan2001 is offline Find More Posts by JazzMan2001
Old Apr 21, 2013, 03:47 PM
stitch1 is offline
Find More Posts by stitch1
Stitching 'em back together!
stitch1's Avatar
United States, MO, Lee's Summit
Joined Jun 2012
I'm excited to see this in person. I think this might be my first wooden plane. I have a real soft spot for the J-3.
stitch1 is offline Find More Posts by stitch1
Old Apr 22, 2013, 02:42 PM
mickydee is online now
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
This little Cub looks good to me. $170 might be a tad high, but not too bad. If this Cub doesn't sell well, that price will come down. I'm not going to be the first on my block to have one, but I am interested.
mickydee is online now Find More Posts by mickydee
Discussion E-Flite 25 J-3 Cub simano Scale ARF/RTF 1165 Sep 10, 2015 06:13 PM
Found WANTED: E-flite J-3 Cub 25 or E-flite Super Cub 25e Retiredtech Aircraft - Electric - Airplanes (FS/W) 4 Dec 04, 2012 02:25 PM
Found WANTED: Hanger 9 Piper J-3 Cub 40, E-flite J-3 Cub 25, or E-flite Super Cub 25e Retiredtech Aircraft - Electric - Airplanes (FS/W) 0 Nov 30, 2012 01:24 PM
Wanted Wanted E-Flite J-3 Cub 25 ARF smileyz Aircraft - Electric - Airplanes (FS/W) 0 Sep 18, 2006 04:12 PM
Discussion NEW E-flite J-3 Cub 25 ARF PLUS 25-Size Fiberglass ARF Floats Jim T. Graham Product Announcements 0 Apr 11, 2006 09:00 AM
