Old Aug 21, 2012, 03:48 PM
mamba max1 is offline
Find More Posts by mamba max1
mamba max1's Avatar
United States, NC, Durham
Joined Jun 2010
Naze32 Q's
Currently building myself another quad. I'm putting a little more money in this one since I can actually fly now. The Naze32 controllers caught my interest because they are small, but also pretty accurate gyro wise.
I'm looking at this one: http://abusemark.com/store/index.php...products_id=30
Currently, I use a Crius board. Since the naze32 doesn't use MW code, is the firmware that is used just as easy to navigate? Also what are the significant differences I'll see over the Crius (aside from physical size and gyro accuracy).
Thanks!
mamba max1 is offline Find More Posts by mamba max1
Old Aug 22, 2012, 08:24 AM
mamba max1's Avatar
Joined Jun 2010
Any input?
Old Aug 22, 2012, 09:43 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I guess there are probably no answers because all this info is either in the wiki or in the afro thread... to ME the advantage is a platform I can develop/debug on properly,
to users I guess:
1) no need to edit/compile/upload firmware to make silly changes like motor mixer or reverse tri servo or switch between PPM and regular RX etc
2) hardware pwm input/output.. no jitter on RC input, 1000+ steps of resolution on output. Combined with proper esc (simonk, esc32, etc), much better stability/response.
3) (and I'm gonna get a lot of hate for this one) platform with at least some future unlike the dead 8bit atmel horse
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 22, 2012, 09:47 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
What is the differences between the Naze32 and NAZA if the end user does not have the resources or means to modify and compile their own firmware? Hmmm.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Aug 22, 2012, 09:52 AM
timecop is offline
Joined Dec 2010
Exactly the guy whose valuable input I've been waiting for in this thread. Tell 'em like it is.
To answer your question,
1) arm-gcc
2) type make
3) done.
wow, that was hard! Almost as hard as downloading tarduino IDE and JAVA.
But to get back ON TOPIC, if MWC-SE works for you, by all means do NOT get anything else. You're not doing me or anyone else any favors by using their hardware. And software is all opensauce, unlike mr. ritchie here implies
Old Aug 22, 2012, 10:22 AM
Joined Aug 2009
When will the airplane mixing be available?
Old Aug 22, 2012, 10:51 AM
timecop is offline
Joined Dec 2010
Whenever I finish wading through the pile of material that is the Output.pde.
Or whenever YOU submit a PROPERLY INDENTED patch, following proper coding style, with all parameters properly configurable via cli/etc.
Honestly though I don't think there's much to salvage from Output.pde, its better to just write it from scratch, which is kind of what I'm going to do whenever I get some free time to do it.
Old Aug 22, 2012, 10:57 AM
Joined Aug 2009
I am not going to submit anything because of the nature of the attitudes. I will stick with what works.
Old Aug 22, 2012, 11:03 AM
timecop is offline
Joined Dec 2010
After seeing your last attempt I'd have to fully agree.
Old Aug 22, 2012, 11:04 AM
Joined Aug 2009
LOL, Bicopter anyone?
Old Aug 22, 2012, 11:06 AM
Joined Aug 2009
The problem from where I sit is, if things does not meet the Almighty TC standard, then it gets bashed. that drives people aka customers and programming help away.
Old Aug 22, 2012, 11:07 AM
timecop is offline
Joined Dec 2010
Referring to: http://www.rcgroups.com/forums/showp...postcount=4677
Old Aug 22, 2012, 11:08 AM
Joined Aug 2009
As stated, that is a WORK IN PROGRESS. Ha!
Old Aug 22, 2012, 11:09 AM
timecop is offline
Joined Dec 2010
The problem from where I sit is, if things does not meet the Almighty TC standard, then it gets bashed. that drives people aka customers away and programming help.
A software project without proper indentation/coding style is doomed to eventually turn into the same kind of mess 8bit MWC is in right now. There's no "almighty tc standard". It's called K&R, you might wanna look it up.
Joined Aug 2009
so code it yourself.
Question Whats up with the 'Q' and 'S' on the Tx Sculptor Beginner Training Area (Heli-Electric) 9 Mar 30, 2012 03:41 PM
Discussion SETUP Q's FOR 'SCALE STYLE' FLYING HeliGriff Scale Helicopters 11 Feb 28, 2012 09:29 PM
Discussion SETUP Q's FOR 'SCALE STYLE' FLYING HeliGriff Large Electric Helis 0 Feb 23, 2012 03:13 PM
Discussion The F.A.Q.s, ma'am, just the F.A.Q.s! Mode One AMA (Academy of Model Aeronautics) 12 Jan 20, 2010 07:23 AM
EP Concept tailrotor q's and DIY rotor q's Scott Coombe Electric Heli Talk 2 May 25, 2003 10:25 PM
