Old Sep 09, 2013, 03:43 PM
Marshfield, Wisconsin, United States
Joined Sep 2002
Old F16 Elevator Question
Putting new rx on f16 not flown in several years, and I forget how the elevator is supposed to function.
Its in delta wing configuration and tx up elevator in my old spektrum D6 causes trailing edges of elevons to go down. Is this correct? Right aileron causes right elevon trailing edge to go up for right bank?
If elevator needs to be reversed, what settings need to be reversed on tx. This is he only delta config Ive ever used, and Im pretty rusty on control setup.
stuka is online now Find More Posts by stuka
Old Sep 09, 2013, 03:48 PM
Joined Sep 2002
OOps.
PHoto stated above.
sorry
Old Sep 09, 2013, 04:04 PM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
For up elevator the trailing edge of the elevons should go UP. As for the right aileron stick the trailing edge of the right elevon should go up and the left elevon trailing edge down. Wait for some conformation on the aileron one though just to be sure I'll double check my F-16 unless someone else chimes in.
Sherlock is online now Find More Posts by Sherlock
Old Sep 10, 2013, 08:06 AM
Joined Sep 2002
Thanks Sherlock. Appreciate it.
Discussion Cermark F16 prop jet question spyderlegs Fuel Plane Talk 3 Jun 04, 2013 11:56 PM
Question GP 70 Elevator hinge questions gagallagher044 Fuel Plane Talk 16 May 17, 2013 01:40 AM
Question elevator setup question for FS9x transmitter i am haji Radios 0 Apr 13, 2013 01:26 PM
Discussion het f16 fan placement question natiho2 Electric Ducted Fan Jet Talk 0 Mar 26, 2013 08:29 AM
Question H9 Taylorcraft dual elevator question romano_st Fuel Plane Talk 9 Jan 26, 2013 09:18 AM
