Old May 18, 2013, 03:19 AM
Dave Pope Manawatu NZ
pope's Avatar
Palmerston North NZ
Joined Dec 2006
2.8 Poor Mans DSer
Hi All,
After a bit of info.
Has anyone bagged a wing with balsa sheeting in the layup, my little brain says it should work but would be good to hear if someone has done it.
Also suggestions on tailplane foils for a T tail, should it be symetrical or a lifting foil, we are running a RK40 on the wing.
Cheers
pope is offline Find More Posts by pope
Old May 18, 2013, 06:56 AM
ETS....Energy retention system
timbuck's Avatar
gold coast australia
Joined Aug 2008
For the wing Dave I'd use .5mm vaneer, much better than balsa.
For the tail....HT14 or 12. Are very popular. Used on many top end moldies today.
http://www.charlesriverrc.org/articl...t-airfoils.htm
Tim
timbuck is online now Find More Posts by timbuck
Latest blog entry: Gizmo 36 pics
Old May 18, 2013, 01:50 PM
pope's Avatar
Palmerston North NZ
Joined Dec 2006
Awesome thanks Tim. RCG is a great source of info instead of playing around in the dark.
The only reason I was going with balsa was that I have heaps of 1.5mm and seeing as its a poor mans play thing it seemed to be the way to go. We were not going to use any but I thought it would help with strength to seperate the composite layers.
some pics for a laugh soon.
Old May 18, 2013, 02:11 PM
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
For DS you might consider some glass under the balsa.
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old May 18, 2013, 04:07 PM
pope's Avatar
Palmerston North NZ
Joined Dec 2006
yes was going to sandwich the balsa with glass and carbon, will be heavy but we get wind .lol
Old May 18, 2013, 04:10 PM
DS Addict
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
the 2.8 PMS (poor mans soarer)
ALEX HEWSON is online now Find More Posts by ALEX HEWSON
Old May 18, 2013, 04:32 PM
Sketchy builder
MatejO's Avatar
Slovenija, Kamnik
Joined Jul 2011
lol
MatejO is offline Find More Posts by MatejO
Old May 18, 2013, 04:45 PM
timbuck's Avatar
Joined Aug 2008
Originally Posted by alex hewson View Post
the 2.8 pms (poor mans soarer)
+1. :d
Old May 18, 2013, 10:01 PM
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
Dave I did all the first SC1, SC2 and Scratcho tails with balsa. Just 3 or 4mm thick. Sometimes I 3M sprayed 2 or 3 layers of thinner balsa together. Just hand shaped the LE roundish, and the TE fairly tapered, concentrating on keeping the shaping symmetrical but about 60% of the surface was just flat. Then vac bagged them with some carbon (on bias) and glass and maybe some strips of unicarbon across the span. Works great. Personally, I have never felt that a flat slab stabilizer or fin loses anything in performance to a special foil.
AvB is online now Find More Posts by AvB
Old May 18, 2013, 11:20 PM
DS Addict
Joined Jul 2005
Just going out to take my PMS for a spin...
HA
Old May 19, 2013, 04:08 AM
pope's Avatar
Palmerston North NZ
Joined Dec 2006
awesome love the name, it will stick, and one can get pms when the wing folds in half.
Us DSer's are a strange bunch, I was saying to Garath the other day. When finishing my new AFP60 it was laid on the bench so it would not get marked, looks great, then we go to a big hill with lots of rocks and no LZ and peg it off. lol
Also when I was power flying and there was a mishap like a wing breaking everyone goes thats bad and are not happy, but for some of us when ripping round the DS circuit BANG goes the airframe and its whoo who, did you see that. lol.
But I must admit its great to build a slopie for a purpose instead of just front flying.
Old May 19, 2013, 05:01 AM
AvB
AvB's Avatar
Joined Nov 2006
Good observational philosophy / psychology there Dave.
Old May 19, 2013, 05:27 AM
DS Addict
Joined Jul 2005
You are a keen man, Dave. You are the NZ Timbo/Andrew equivalent =)
Old May 19, 2013, 05:49 PM
No, it won't buff out.
gizzo's Avatar
Adelaide, Australia
Dave, I've bagged a bunch of wings with balsa. I think it's great. It's easy to work with. My little Atom planks are blue foam core, 1mm balsa skins and couple layers of glass and hardwood LE and they are pretty tough. Outlaw speedo is same. It's really easy at those little sizes 'cause you don't need to bother with a spar. I guess if yours is 2.8 your gonna need something. Anyway, considering loads of mouldies are just a couple layers of glass seperated by a balsa core, it cant be any worse than them.
My 2c, YMMV, IMO etc
simon
gizzo is online now Find More Posts by gizzo
Old May 20, 2013, 05:14 AM
pope's Avatar
Palmerston North NZ
Joined Dec 2006
progress
A few pictures, a expo spar, pine 20mm lam with carbon and strip aluminium. Test spar was installed into my AFP75 with carbon to cover all surfaces. So we will see how it goes.
Wing cut and taped, need a longer bench. the wing will be a 3 piece 1400mm centre and plug in 700mm tips.
The templates look different but its a wire cut method the we now use for live hinges.
The foam is cut to the airfoil on the bottom surface and the TE is thickened on the top to get a good TE. then just before bagging to top surface is sanded down to mico thin. (love green foam) If you don't know what I mean and are interested I can do a video of the process. But then maybe it's old news.
LE are now on and spar layout has been worked out but lost the photo, so might post tomorrow night.
Question Poor Man's SBEC? Aerospacer Power Systems 0 Apr 16, 2013 04:21 PM
Discussion Poor Mans Micro Brushed ESC/Actuator Driver/LED Proportional with trim elvill Micro Ready-to-Fly 5 Jan 18, 2013 01:12 AM
Discussion PMG-RB-2, or Poor Man's Goggles, by Reckless Bill, version 2. Cathay Stray FPV Talk 0 Oct 28, 2012 09:37 PM
Kyosho 180 Poor Man's Power Fix??? Don Sims Electric Plane Talk 41 May 12, 2001 09:23 PM
