Old Yesterday, 12:52 PM
Joined Dec 2013
3 Axis Gyro on A Foam Profile
I have a techone YAK 1100 and want to use a Thunder P1-Gyro on it. Since its a profile my mounting options are limited. The instructions (my first Gyro) say it must be mounted horizontally and right side (top) up. If I mount it under the wing, I can't get to the gain pots for adjustments unless I mount it upside down. Can I mount it on its side on the side of the profile body? Better yet, has anyone used of these and has a quick "cheat sheet" I could use? I didn't see any videos on youtube that looked like they would tell me anything.
senator59 is offline Find More Posts by senator59
Old Yesterday, 03:17 PM
Joined Dec 2013
I have been in the garage for a couple of hours trying to figure this thing out. Its actually pretty logical. It must be mounted right side up so the elevator gyro responds in the right direction. If its upside down, the gyro thinks the plane is flying inverted. More expensive gyros have reverse switches but this Chinese stuff does not. As for mounting on the side of the fuze, same effect. The ailerons will be screwed up. Lesson to be learned here is to hook it all before you epoxy the wings in!
Question 3 Axis Gyro's on 30 -50cc Gas Planes Rich215 Fuel Plane Talk 15 Feb 05, 2014 01:13 PM
Discussion 3 axis gyro RX on a Align 450 larryb Electric Heli Talk 4 Dec 12, 2013 07:37 PM
Discussion Using the switch feature on a 3 Axis Gyro WarlordATF Electric Plane Talk 0 Nov 07, 2013 03:06 AM
Question Multi Blade helis....regular gyro or 3 axis gyro Maduro Mini Helis 4 Oct 29, 2013 12:04 PM
Sold Futaba CGY750 GYRO, 3-Axis Gyro & Governor for sale rcedge Aircraft - General - Radio Equipment (FS/W) 1 Oct 20, 2013 10:45 AM
