Old Mar 06, 2013, 10:25 PM
Joined Mar 2013
Help!
Brand New 10XP charger issue
I have a brand new 10xp which despite reading the manual several times, I can not get to work with my Turnigy Li-po packs. I'm using the cp10s-gp/k06s and the cp-gp/ko adapters. No matter what the node wiring setting is, I get a bad S. count error every time. I have a older 10S charger when used with the above adapters and same packs, works every time no issues. Am I missing something?
Thanks.
Rick
San Diego, Ca.
Rickatsea is offline Find More Posts by Rickatsea
Old Mar 06, 2013, 10:51 PM
Seattle
Joined Sep 2007
What wiring mode are you in? Should be in FMA wiring mode for those adapters. From the manual
Special Button Operation:
Press and hold MODE button while applying power to access and scroll the Options menu: CHOOSE SPLY AMPS, LOWS SUPPLY VOLTS, NODE CONNECTOR, QUIET CHARGING, Exit. Use the Options Menu to choose input amps limit and supply low voltage setting (Power Management feature), alternate between FMA or XH balance wiring schemes, and set quiet charging (no speaker beeps during charging).
Gregor99 is offline Find More Posts by Gregor99
Latest blog entry: Dual Powerlab Case Project
Old Mar 07, 2013, 07:42 AM
United States, MN
Joined Feb 2011
Did you connect the main leads? The 10xp can not node charge while the 10S can.
As Gregor99 said, if using a FMA adapter you need to be in FMA wiring mode.
grimbeaver is offline Find More Posts by grimbeaver
Old Mar 07, 2013, 08:13 AM
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Thanks.
Rick
San Diego, Ca.
Hi,
Also, for 2S - 5S packs, only connect the RJ1 pigtail to channel 1 and do not connect the 2nd pigtail from the adapter to the charger. If you connect both pigtails to the adapter for 2S - 5S packs, the charger will error. FYI - the plug blocker is not compatible with the 10XP.
Howard Matos is offline Find More Posts by Howard Matos
Old Mar 07, 2013, 09:31 PM
Joined Mar 2013
Thx but no go
Thank you for the responses I received. However, I had covered those issues before I posted and I indicated that I had tried the node wiring settings both of them for shits and giggles. Unless I'm using the wrong adapters, which I don't believe I am, there's something else a miss. It still could be me though. I emailed Revolectrix tech support for help also.
Old Mar 08, 2013, 08:53 AM
United States, MN
Joined Feb 2011
What Howard said seems the most likely issue. Did you connect both wires from the board to the charger or just one?
Old Mar 08, 2013, 09:14 AM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Save everyone some time and post a couple pictures of everything connected.
Rick
rampman is online now Find More Posts by rampman
Old Mar 09, 2013, 03:51 PM
Frontenac, KS
Joined Jan 2003
Here are the pictures of mine.
Just got two 10XP chargers replaced.
Opened one and hooked up.
FMA note or XH node doesn't matter.
Ch1 Bad S. Count Note wiring FMA, or XH
Pack is 3s 1000mah hooked up to only one port with one board (GP)
Charger has 1226 printed on the bottom.
Going to try the 2nd charger.
PatternFlyer is offline Find More Posts by PatternFlyer
Old Mar 09, 2013, 03:55 PM
Frontenac, KS
Joined Jan 2003
I just tried 2nd charger. Does the same thing as 1st charger.
Old Mar 09, 2013, 04:40 PM
Seattle
Joined Sep 2007
On the charger, move the red charge lead to the far right banana jack.
Old Mar 09, 2013, 09:48 PM
Frontenac, KS
Joined Jan 2003
Got it working. I can't believe how I miss that.
Thanks!
New Product Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 368 Jun 25, 2014 05:17 PM
Discussion FMA Cellpro 10XP Charger alexf1852 Batteries and Chargers 77 Feb 13, 2014 08:20 AM
Help! Brand New Dynam A-10 Issues Buzzbombkirk Electric Ducted Fan Jet Talk 7 Feb 13, 2013 11:59 PM
Sold Like-New Cellpro 10XP, 15A, 600W 10s Multi-Chemistry Charger teryn1 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 07, 2012 12:32 PM
Sold New Cellpro 10XP, 15A, 600W 10s Multi-Chemistry Charger teryn1 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 30, 2011 08:34 AM
