Old Jul 26, 2014, 08:59 PM
Markran's Avatar
United States, CA, Sacramento
Joined Aug 2011
Combining resistor values for SMD LEDs
I'm adding SMD LEDs to my plane and am using the usual calculator (http://led.linear1.org/led.wiz). However, the calculator shows a resistor for each LED, in my case a 56 Ohm. I'm wondering if it's possible to combine values and use only one 110 Ohm resistor with both negative lines tied to it?
Markran is offline Find More Posts by Markran
Old Jul 27, 2014, 03:14 PM
Markran's Avatar
Joined Aug 2011
I found a better calculator that has options to determine resistor values for multiple LEDs in series or parallel.
http://www.hebeiltd.com.cn/?p=zz.led...tor.calculator
Discussion SMD LED install Blade Nano QX Fyathyrio Mini Multirotors 76 Jun 03, 2014 04:57 PM
Discussion LadyBird Qr SMD Led's mod, even more led's to come! croyal918 Multirotor Talk 6 Jan 13, 2014 07:15 PM
Discussion smd resistors again.. Chippie DIY Electronics 5 Oct 23, 2008 03:37 AM
Resistor values for LED's please tipperary Electric Plane Talk 3 Oct 20, 2005 03:24 PM
