Old Jul 26, 2014, 09:47 AM
United States, IL, Monticello
Joined Sep 2013
Fiberglassing Skywalker 1680
Hi guys. I recently finished a scratch built Skywalker 1680 and got a lot of good flights in before I clipped the top of the tree and the tail came off and it came crashing down in pieces.
I want to rebuild and was wondering if it would be worth it to fiberglass it. I built it out of EPS so I don't really know how the usual fiberglass techniques will work on it. If you think it's worth it let me know and maybe some tips on how to do it.
AlmondBark is offline Find More Posts by AlmondBark
Old Jul 26, 2014, 05:38 PM
Lower Blue Mountains, Australia
Joined Jan 2006
I laid some 48g/m cloth around the boom, and a little bit either side to the fuselage and tail, to stiffen up the wobbley tail. I used Zap Z-Poxy resin. It's excellent on foam and remains a little flexible so it won't crack if it gets a sharp knock (particularly on a hard landing and the tail bounces around).
You could probably get away with even lighter cloth (20g/m?) if you're only using it to smooth repairs/joins rather than adding strength.
Dr. |2udie is online now Find More Posts by Dr. |2udie
Old Jul 27, 2014, 08:48 AM
Joined Sep 2013
Thanks for the reply Doc. How was your experience with z poxy? I have read that it is rather thick and not the easiest to use compared to laminating epoxies. I was thinking of going with us composites or ezlam from acp composites.
Old Jul 28, 2014, 07:03 AM
United Kingdom
Joined May 2013
I've used z-poxy in the past for skinning balsa models, it's really nice to work with. Can't say I've ever found it too thick, if it was, then a little bit of heat will resolve that. I've also used the West Systems epoxy as well, which is what I laminated my 2013 Skykwalker fus with. If you leave the West Systems more than a couple of days, it is much harder to rub back than the z-poxy.
The biggest issue I had when doing this on the Skywalker was getting it to stick well to the foam. If you are 'wrapping' it around the boom, then that won't be a problem, but any 'edges' are prone to lifting.
Chris
hangarspace is offline Find More Posts by hangarspace
Found Skywalker 1680 blueprint FPV Equipment (FS/W) 0 Oct 26, 2013 01:35 PM
For Sale SkyWalker fuselage EPO for Skywalker 1900,1880,1680 RC4YFPV FPV Equipment (FS/W) 2 Jun 03, 2013 10:36 PM
For Sale Old SkyWalker fuselage suitable for Skywalker 1900,1880,1680,only $59.99 RC4YFPV FPV Equipment (FS/W) 1 May 08, 2013 10:56 AM
For Sale 20 unit Skywalker x8 and 12 unit Skywalker 1680 shipped in 12hours delivery RC4YFPV FPV Equipment (FS/W) 11 Feb 04, 2013 07:34 PM
Discussion Which plane Skywalker 1680/1900, Super Skysurfer caall99 FPV Aircraft 14 Jan 22, 2013 03:13 AM
