Old Mar 02, 2010, 01:01 AM
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Data
Cool New Tip!
Ok so Im building a new 5mm EPP plane and had decided to use flat 5mm carbon in the wing as the main brace so here the methos I came up for cutting a perfect slot in the foam
Items needed for method
" DONT THROW AWAY THOSE OLD #11 BLADES"
And if you have a candle handy your good to go.
tallflyer is offline Find More Posts by tallflyer
Old Mar 05, 2010, 06:29 AM
sturdybird46's Avatar
Hayward, Ca
Joined May 2004
I use to have a hobby hot knife. It was basically a soldering iron with a #11 tip that I picked up at Michael's. Last time I tried CF strips I used white gorilla glue. What type of glue is working out for you with EPP?
sturdybird46 is offline Find More Posts by sturdybird46
Old Mar 05, 2010, 09:27 AM
tallflyer's Avatar
Joined Jul 2002
Since trying this method I went with 5 minute epoxy I like to wipe it on both sides with a stir stick from starbucks and then press it in place, drag over the carbon with a extra piece of epp to push any extra epoxy down around carbon, then apply small pieces of painters tape to hold it all tightly together and then lay some weights on it to make sure it dies flat.
Latest blog entry: New GoPro Hero3+ Black Edition
Old Mar 05, 2010, 02:29 PM
Hayward, Ca
Joined May 2004
What is the thickness of your carbon? Do you sell it on your site?
Old Mar 05, 2010, 07:32 PM
tallflyer's Avatar
Joined Jul 2002
The carbon is is from rcskyflyer here in CA I did not have any on hand and I order a few rods from then as my other dealer did no have any
Sold Like new 3.8X Xplorer with 3.5 tip/tail set gliding Oz Aircraft - Sailplanes (FS/W) 3 Mar 29, 2010 07:49 AM
Discussion Securing batter +new tip grumman1 Foamies (Scratchbuilt) 0 Nov 05, 2009 10:38 PM
For Sale Ava Wing Tip Purple-Violet New Right Tip!!! orbitone Aircraft - Sailplanes (FS/W) 0 Nov 11, 2008 12:29 PM
homemade brushless cool tip..... iflyrc71 Power Systems 8 Sep 06, 2004 01:59 PM
