Old Mar 17, 2004, 11:49 PM
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
Extra 3D Adrenalin and some Q's
I ordered the plane from NESail with the Rotex package. Doesn't say what prop it comes with but I do have a question about the props.
According to this chart:
Motor Prop (GWS) Battery Amps Thrust (gms)
Rotex 25/6/15 10 x 4.7 2-cell Li-Poly 5 270
Rotex 25/6/15 11 x 4.7 2-cell Li-Poly 6 310
Rotex 25/6/15 9 x 5 3-cell Li-Poly 7.5 440
Rotex 25/6/15 10 x 4.7 3-cell Li-Poly 10.2 500
Rotex 25/6/15 11 x 4.7 3-cell Li-Poly 10.5 550
If I were to use the 10x4.7 GWS props which pulls out 10.2 amps of current load with the 10 amp esc it comes with, would it fry the esc???
reason I ask is because I have a few 10x4.7 props that can be used. I want to put them into good use and not just let it sit there..
Boy I can't wait for some brushless action.
Oh one more thing. it comes with the 700mAh 3 cell lipo. Could I go with 800s or even 1200s??
I would like to use 2 cells instead of three. If using 2 cell is possible for this motor setup, how much mAh would be needed to draw enough power for the motor? I was thinking like a 2 cell thunder power 2100 or something similar without drawing over 10 amps
-Tomi
tomi is offline Find More Posts by tomi
Old Mar 18, 2004, 03:37 PM
Fly like an... airplane?
mike98624's Avatar
Milford, NJ
Joined Oct 2002
i don't know anything about this plane, but i'm guessing that TP 2100s are gonna be a little much, considering that stock is a 700. Also, the TP 2100s can easily handle 20 amps.
mike
mike98624 is offline Find More Posts by mike98624
Old Mar 18, 2004, 09:13 PM
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
So it would make a difference if the 3 cell was at 700mah and the 2 cell at 2100mah?
Old Mar 18, 2004, 09:19 PM
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
okay nevermind. The TP cells pull out 12-14 amps.
Now I just found out about Tanic Lipos. 1100mah 2 cells pull out 10-11 amps. Should I be safe with the CC 10 amp esc?
FS: Free Air Extra 3D adrenalin tomi Aircraft - Electric - Airplanes (FS/W) 1 May 22, 2004 04:24 PM
FS: RTF Extra 3D Adrenalin - minus RX tomi Aircraft - Electric - Airplanes (FS/W) 1 Apr 24, 2004 10:26 PM
Extra 3D servos ( 4.9's Discontinued? ) rickc 3D Flying 2 Apr 03, 2004 03:36 PM
eclipse spectra users- some q's DesignGeek Electric Plane Talk 9 Aug 25, 2002 09:14 PM
got some q's about my t-52 logan5 Foamies (Kits) 2 May 09, 2001 09:00 PM
