Old May 16, 2013, 10:56 AM
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
APM 2.5 Configuration File for X8?
Hi All,
Does anyone have an APM 2.5 configuration file for an X8?
Thanks!
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old May 24, 2013, 02:57 PM
Control the Truth#1 goal inWAR
TonyTronicWSP's Avatar
United States, WA, Walla Walla
Joined Oct 2012
All the APM 2.5+ hardware is the same; you just click on an icon in the Mission Planner to tell it what kind of vehicle you want to use it with (multicopter, plane, rover, traditional heli, etc) and it automatically loads the correct firmware.
The Mission Planner is Windows-only, but once you've loaded the correct firmware you can use any Ground Station, including QGroundControl (Win, Mac and Linux) or various mobile/tablet GCSs, such as Andropilot and Droidplanner.
The APM community and support is at DIY Drones, so you'll get the best help in using it over there.
copied from chris anderson post.
TonyTronicWSP is offline Find More Posts by TonyTronicWSP
Latest blog entry: IRIS Pixi replaced first flight
Old May 24, 2013, 10:34 PM
Zephyr41's Avatar
Malanda, QLD Australia
Joined Jul 2004
Hi Jimmy, your best chance of getting the config file is on the DIYDrones forum.
http://www.diydrones.com/forum
There's a forum for collecting copter config files but none for ArduPlane files (that I could find).
If you post a request in the 'Aircraft Platforms' forum you will probably get a good response.
http://www.diydrones.com/forum/categ...istForCategory
Cheers
Rich
Zephyr41 is offline Find More Posts by Zephyr41
Old May 25, 2013, 10:38 AM
Inherent Tinkerer
Joined Jul 2003
Thanks, Rich.
I'll post a note there.
Jimmy
Sold APM 2.5 ReadytoFlyer 2.5 with GPS 915Mhz Telemtry, Mavlink OSD and 3dR case Wingbreaker Aircraft - Electric - Multirotor (FS/W) 2 Feb 28, 2013 11:38 AM
Sold APM 2.5 ReadytoFlyer 2.5 with GPS 915Mhz Telemtry, Mavlink OSD and 3dR case Wingbreaker FPV Equipment (FS/W) 0 Feb 28, 2013 11:26 AM
Found ArduPilot 2.5 - APM 2.5 or Arduflyer jjmelo Aircraft - Electric - Multirotor (FS/W) 13 Feb 12, 2013 03:13 AM
