Old Jul 28, 2014, 02:07 AM
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
No spare parts? I am thinking there are... (check over here, it's been discussed before.
Also, if you like it a lot, you could buy a spare.
Propeller could be anything. Are you swapping the motor?
If you run stock motor, you could add a cell and go to same size 2 blade.
Personally, I like the plane due to it's air presence. However, these days I prefer the balsa stuff.
struggleforlife is online now Find More Posts by struggleforlife
Old Jul 28, 2014, 04:56 AM
Joined Oct 2013
Do you mean I can buy a used plane?
joker208 is offline Find More Posts by joker208
Old Jul 28, 2014, 09:14 AM
Joined Feb 2011
Pfew, i don't know. But
Doesn't HK offer this plane for a decent price?
Old Jul 28, 2014, 06:33 PM
Joined Oct 2013
It's sold out at Hobbyking, but there's a couple of other places that sell it.
Old Aug 10, 2014, 11:00 AM
krazyman's Avatar
United States, AZ, Camp Verde
Joined Jan 2007
I am thinking about buying this plane, but was wondering how it compares to the FMS 1400 mm? I know it is bigger, but less money. How good are the electronics and retracts?
Terry
krazyman is offline Find More Posts by krazyman
Old Aug 10, 2014, 10:04 PM
Beancounter's Avatar
United States, MA, Sterling
Joined Sep 2009
Stock retracts are garbage if you search this thread you will see that most of us have replaced them hobby king 514 or 716 size retracts.
Beancounter is online now Find More Posts by Beancounter
Old Aug 11, 2014, 07:28 AM
krazyman's Avatar
Joined Jan 2007
I have been reading through this thread and I understand the retracts are junk. I will probably replace them with the ones that FMS uses for the P-51.
Terry
Old Aug 14, 2014, 08:16 PM
Joined Oct 2013
Does this plane have too much glare in the sun?
Old Aug 17, 2014, 03:41 PM
United States, AL, Northport
Joined Apr 2010
1400mm FMS planes have an all metal upgrade and it's the same size as the stock starmax ones. It's the legs that are crap on the new gear so that is what really needs to be swapped out.
Check out PW-RC for a full line of gear
Razerworkz is offline Find More Posts by Razerworkz
Old Aug 17, 2014, 07:18 PM
krazyman's Avatar
Joined Jan 2007
What legs are crap? FMS or Starmaxx? What do I need as far as length of strut and what diameter? I would like to have good landing gear ready to put in before I get the plane. Otherwise I might not be able to resist the temptation to fly it with the lousy gear.
Terry
Old Aug 18, 2014, 12:02 AM
Joined Apr 2010
Starmax as least mine where on my grass field. They worked but they flexed too much.
I swapped out my Skyraider with a set that matched the same size much were built better and better rotating setup.
Old Sep 22, 2014, 12:18 PM
United States, OH, Chagrin Falls
Joined Apr 2013
Well, this seems like a fairly dead thread...
But has anyone swapped out the rear retract unit and doors with one for the 1700 FMS P47? That pull-pull system is a pain.
http://www.diamondhobby.com/airplane...ding-gear-door
http://www.diamondhobby.com/airplane...retract-system
dsa44 is offline Find More Posts by dsa44
Old Sep 22, 2014, 07:23 PM
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
http://www.rcgroups.com/forums/thumb...rter=no&page=2
http://www.rcgroups.com/forums/searc...=fms%20retract
mcnowhere is offline Find More Posts by mcnowhere
Old Sep 22, 2014, 07:57 PM
Joined Apr 2013
Thanks McN! I remember you from the T28 or P51 forums! (both of which I try to fly regularly!) Small world, eh? Yea I had already looked over all the images in the thread, and searched for retracts, etc., just didn't see anything specific about using the 1700 fms rear unit in the back. I have already upgraded the mains with beefy oleos, but that darned pull-pull system in the back is a real pain. I went and ordered those fms parts, so I will see if I can do a retrofit when I get some time. Just hoping someone might have done it already.
Cheers!
Old Sep 22, 2014, 08:23 PM
Look out below
mcnowhere's Avatar
Joined Aug 2011
Yep the T28 thread. Not many have had problems with the pull pull. Using a piece of wire and quick connects works best. Like this guy http://www.rcgroups.com/forums/showp...&postcount=696 I think I also crossed the strings and reversed the servo, a little tip I found really helps. I know I did it on another plane but can't remember on this one. Once you get used to doing them its easy. Its already tail heavy so how much weight are your fms parts? Thats why the pull pull.
Help! Starmax P-51 Parts Kevin Greene Vendor Talk 0 Mar 11, 2011 10:56 PM
Discussion ParkZone P-47 Thunderbolt avengedkevinfold Electric Plane Talk 1 Mar 03, 2011 02:40 PM
