Old Apr 22, 2009, 05:26 PM
Lake Saint Louis MO
Joined Apr 2009
quick Miss Vegas question
Ok, My recoil starter is shot on my miss vegas. Does anyone know if there is an electric starter that will fit this boat or should I just rebuild or by a new recoil?
Midwestracer is offline Find More Posts by Midwestracer
Old Apr 22, 2009, 05:47 PM
I didn't have to use my AK
avoidingexpert's Avatar
United States, NC, Etowah
Joined Nov 2007
Its time for a belt starter!!! I have no idea if there is a tiger starter for these, but once you go belt you never go back!!
avoidingexpert is offline Find More Posts by avoidingexpert
Old Apr 22, 2009, 06:33 PM
Lake Saint Louis MO
Joined Apr 2009
can you recommend a belt starter?
Old Apr 22, 2009, 06:36 PM
Detroit
Joined Aug 2006
How is it "shot?" is it not turning the engine over, or did something come apart?
I have the same engine (OS .18) in my 1/12 Pro-boat, and had problems with the recoil starter too. It wasn't reliably turning the engine, as though something inside was slipping. I ended up having to replace the one-way bearing and stub shaft. Apparently the recoil assembly on this engine likes to trap water, and the one-way bearing dries out too.
I would just replace what needs to be replaced on the recoil; in my opinion the only workable electric starters for something this small aren't worth the hassle.
edit: I hadn't looked at the Miss Vegas's flywheel before I posted this. It does look like it's machined to take a belt, unlike the Pro-Boat hydros. Pretty much any belt starter setup would work, that little .18 is nothing to crank over. Aquacraft offers their "GrimRacer" belts, and any Hobbico "Torqmaster" starter should be sufficient.
jz78817 is offline Find More Posts by jz78817
Old Apr 23, 2009, 12:11 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Hand-held electric starters will spoil you rotten! What's nice is that almost any low-dollar one on a 12 volt gel cell battery will turn over your .18 with no sweat. I'm a little crazy but crank mine over on 24 volts with a Sullivan Dyna-Tron.
Ron Olson is offline Find More Posts by Ron Olson
Quick Lithium battery Question GKP27 Batteries and Chargers 4 Nov 04, 2003 03:19 PM
Quick TM batt question Rxb Parkflyers 3 Dec 15, 2002 01:42 AM
Quick Piccolo Rx Question AirVenture Electric Heli Talk 4 Aug 28, 2002 07:55 AM
Hobby Lobby Miss 2 Question xjohnx Parkflyers 7 Nov 23, 2001 02:02 AM
