Old Nov 28, 2007, 06:02 AM
szewang2805 is offline
Find More Posts by szewang2805
Joined Dec 2006
Do you know the Advantages of Digital Servo?
Higher resolution-less deadband, more accurate positioning
1. Faster control response-increased acceleration
2. Constant torque throughout the servo travel
3. Increased holding power when stationary
The "Analog Servo" has custom Logic chip and timing components
The "Digital Servo" has a microprocessor,FET amplifier.
There are two main categories of servos available, analog and digital. Analog servos have been around for quite some time, servos work by sending pulses of power to the servo motor, similar to the way an ESC powers an electric RC truck. However Digital servos have significant operational advantages over analog servos, but with these advantages also come minor disadvantages, and this fact file will try to explain the positives and negatives of Digital servos in simplified terms.
First of all, a digital servo is the same as a traditional servo. Digital servos have the same motors, gears and cases as analog servos and the greatest difference between them is on the controlling circuit, the Digital Servo has a Quartz crystal controlled microprocessor, FET amplifier, which has a decisive influence on the performance of servos.
Where a digital serve differs, is in the way it processes the incoming receiver information, and in turn controls the initial power to the servomotor. Due to a small microprocessor inside the case, can specifically tailor the pulses being sent to the servo's motor. It can also send a larger number of pulses, which means that the range of motion can be broken down into a much finer pattern. Since more pulses are being sent, the servo is more responsive and contains a significantly less amount of deadband.
In a conventional servo, no power is being sent to the servomotor. When a signal is then received for the servo the move, or pressure is applied to the output arm, the servo responds by sending power/voltage, is pulsed or switched On/Off at a fixed rate ,creating small 'blips' of power. By increasing the length of each pulse/blip of power, a speed controller affect is created, until full power/voltage is applied to the motor, accelerating the servo arm towards its new position.
In turn, as the servo positioning pot tells the servo's electronics it is reaching its required position, the power blips are reduced in length to slow it down, until no power is supplied and the servomotor stops.
The Distinct Advantages of a Digital Servo.
First, it equips with the microprocessor, to receive the incoming signal and apply preset parameters to that signal before sending its pulses of power to the servomotor. This means the length of the power pulse/blip, and therefore the amount of power sent out to activate the motor, can be adjusted by the microprocessors program to match its function requirements and therefore optimize the servo's performance.
The second, is that a digital servo sends pulses to the motor at a significantly higher frequency. This means that, as opposed to the motor receiving 50 pulses/sec., it now receives 300. Although the length of the pulses is reduced in a direct ratio to the higher frequency because the power is being turned on/off to the motor more frequently, the motor has more incentive to turn. This also means that not only does the servomotor respond faster to the commands, but that increases or decreases in power for acceleration 、deceleration are able to be transmitted to the servomotor far more frequently. This gives a digital servo an improved deadband, a faster response, quicker and smoother acceleration/deceleration, and better resolution and holding power.
The Disadvantage of a Digital Servo.
Digital servos are definitely more advanced than their analog counterparts. However there is one disadvantage to digital servos, they use more power. Digital servos will drain a battery quicker than an analog servo would. Also running multiple digital servos is generally a bad idea due to the added current draw that they can pull when operated together. In situations where multiple digital servos are used, such as planes, special wiring and extra batteries are the preferred route.
Digital servos are the future for model control, and anyone who has used them says the difference is so significant that they would never return to analog servos, if there is a digital one available to fit the application.
Therefore, Flyermate Industrial Company designed and produced the Flyermate D55.0 Genuine Digital Servo which is the only solution!
Specification of Flyermate D55.0 Genuine Digital Servo:
-Operating Angle: 180degree
-Gear Material: Copper
-Weight: 55.0g
-Operating speed:
0.15sec/60 degree(4.8v)
0.13sec/60 degree(6.0v)
-Stall torque:
8.8kg/cm(4.8v)
10kg/cm(6.0v)
-Operating Voltage: 4.8v - 6.0v
-Operating Current: 1~3A
-Wire Length: 30.6cm
-Dimension: 41.0mm X 20.5mm X 41.5mm
Contact: www.flyermate.com
szewang2805 is offline Find More Posts by szewang2805
Reply With Quote  (Disabled)
Old Nov 28, 2007, 06:21 AM
summerkc is offline
Find More Posts by summerkc
EMB Jungle Jet Jockey
Georgetown, IN across the Ohio River from Louisville, KY
Yeah, but do you know the advantages of reading the forum rules?
summerkc is offline Find More Posts by summerkc
Old Nov 28, 2007, 07:16 AM
xwingnut is offline
Find More Posts by xwingnut
xwingnut's Avatar
The Great NorthWest
Joined May 2007
And a CHEAP DIGITAL servo is no better than a mid-range analog servo which is a much better value!!
xwingnut is offline Find More Posts by xwingnut
Old Nov 28, 2007, 08:10 AM
canardman is offline
Find More Posts by canardman
Ready for some cooler weather
canardman's Avatar
Waco, TX
Joined Jan 2006
Ummm... I'd like to just jump in here and say..
*EDIT* "Someone found my post offensive" I forgot about the PC rules here. Sorry
canardman is offline Find More Posts by canardman
Old Nov 28, 2007, 08:16 AM
qualcity is offline
Find More Posts by qualcity
WHOHH..You See That??
qualcity's Avatar
Aurora, Colorado
Joined Jan 2005
OMG canardman...
That was just toooooo darn funny. Had me laughing out of my chair!!! Hahahahaha..
qualcity is offline Find More Posts by qualcity
Old Nov 28, 2007, 10:46 AM
dougmc is offline
Find More Posts by dougmc
Doug McLaren
dougmc's Avatar
Austin, TX
Joined Jan 2004
Originally Posted by szewang2805
... and anyone who has used them says the difference is so significant that they would never return to analog servos, if there is a digital one available to fit the application.
Hardly. They're nice, sure, but I'm not going out and replacing all my analog servos. I'm not even buying only digital servos -- I'm still buying both sorts of servos based on my needs, and often analog still wins -- usually because it's a lot cheaper.
Well, the only solution ... if you ignore all the other solutions.
Nice ad, by the way. Too bad you put it in a place not meant for ads.
dougmc is offline Find More Posts by dougmc
Old Nov 28, 2007, 11:35 AM
summerkc is offline
Boooooooooo!
Old Nov 28, 2007, 12:22 PM
dessertracer is offline
Find More Posts by dessertracer
dessertracer's Avatar
Joined May 2006
So what's being sold?
dessertracer is offline Find More Posts by dessertracer
Old Nov 28, 2007, 02:21 PM
summerkc is offline
A bunch of lies.
And some crappy servos.
Old Nov 28, 2007, 02:43 PM
ghostmechanic is offline
Find More Posts by ghostmechanic
1 paycheck away from homeless
ghostmechanic's Avatar
United States, KS
Joined Mar 2006
I found this part hilarious.
Go away spammer!
ghostmechanic is offline Find More Posts by ghostmechanic
Old Nov 28, 2007, 04:12 PM
steve1814 is offline
Find More Posts by steve1814
One cell short of a Pack
steve1814's Avatar
Good ole Smithsburg, MD
Joined Mar 2007
21 Post this user has and they are ALL AD Spam. Why hasn't he/she been booted yet?
steve1814 is offline Find More Posts by steve1814
Question How do you know a servo is bad? HELModels Radios 33 Jul 25, 2006 10:47 PM
Do you know this motor? jjkwang Parkflyers 3 Jul 04, 2001 09:55 PM
do you know some sites on building fiberglass fuses? i-fly Electric Plane Talk 1 Jun 10, 2001 09:36 PM
Aeronaut Aerofly .... Do you know of this plane? DocMac Electric Sailplanes 2 Jun 07, 2001 11:42 PM
Need to sell a slimer...do you know where? rc capo Electric Plane Talk 3 May 23, 2001 12:42 AM
