Old Jun 30, 2015, 07:42 AM
jermar is offline
Find More Posts by jermar
United States, NY, New York
Joined Jul 2013
I've had good luck in the past with Ebay Nano's. Now I've received my second Nano with the same board problem. My rates are at 125%, but it performs as if it's locked in beginner mode. It flies fine, but at super reduced rates. Interesting that both of these bind after only one light blink, instead of the usual five. Any advice appreciated.
jermar is offline Find More Posts by jermar
Old Jun 30, 2015, 07:50 AM
Bush Pusher is online now
Find More Posts by Bush Pusher
What goes up must come down
Bush Pusher's Avatar
United States, NH, Rochester
Joined May 2014
Is it possible that the control board is like other Blade 3 in 1 main boards and while binding you have to move the rudder stick to the right so the board knows its a computer radio ?
Bush Pusher is online now Find More Posts by Bush Pusher
Old Jun 30, 2015, 08:46 AM
SoloProFan is online now
Find More Posts by SoloProFan
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Rates are not always a matter of travel adjust, but more often a switch needs to be flicked to switch to high rates. Like on the msr when you used a more advanced radio, it had to be set in acro mode, and the channel 5 gyro/landing gear controlled the rates,
SoloProFan is online now Find More Posts by SoloProFan
Old Jun 30, 2015, 08:54 AM
jermar is offline
Joined Jul 2013
Thanks for trying to help Bush. On my orange Tx moving the rudder stick as suggested produced no change. I tried the stock Tx and it behaves the same. Isn't the strange light blinking cause for concern?
Old Jun 30, 2015, 10:55 AM
jermar is offline
Joined Jul 2013
Thanks Solo, but I'm comparing these Nanos to the other five I own. I only fly in stability and the others fly fine. Have you seen a Nano show solid blue after only one blink?
Old Jun 30, 2015, 11:51 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Mine also blink a few times, so that's indeed odd. Maybe a copy? It's not hard to make a spektrum compatible receiver.
Old Jun 30, 2015, 01:03 PM
CraigHB is offline
Find More Posts by CraigHB
crash tested
United States, NV, Reno
Joined Dec 2014
Have a Nano QX, great little pocket quad. Too bad I didn't see the links before about the props and the motors. It is a bit ridiculous what HH charges for that stuff. Didn't know you could overdrive the servo travel in the TX to get higher rates. Don't really need it, but nice to know I can. Using a DX6 TX, just need to put channel 6 on a two position switch for +-100 to switch the modes, but I don't understand why you have to cycle it off/on/off to change the mode, sort of odd.. Rate mode is definitely twitchy. It's a dramatic difference from attitude (safe) mode, need a lot of expo to tame it down.
CraigHB is offline Find More Posts by CraigHB
Old Yesterday, 06:48 PM
Multirotor Go is online now
Find More Posts by Multirotor Go
Multirotor Go's Avatar
Joined Jan 2015
Phoenix Flight Gear 110mm 7mm Micro Motor Warehouse Quadcopter Maiden Flight
After so many month waiting for all the parts I made my first build And I love it!
With Nano QX FC board
If you have more than one NQX I say it is a must
Better power 7mm motors, 350mah
Phoenix Flight Gear 110mm 7mm Micro Motor Warehouse Quadcopter Maiden Flight my first build RC drone (4 min 57 sec)
Multirotor Go is online now Find More Posts by Multirotor Go
For Sale Ethos QX 75 Nano-Micro RTF Quadcopter, Red - $100+ worth of extra parts included vcantrell Aircraft - Electric - Multirotor (FS/W) 3 Dec 20, 2014 06:46 PM
For Sale New Unopened Blade Nano GeicoGecko Aircraft - Electric - Helis (FS/W) 4 Dec 16, 2014 07:23 PM
Discussion Ares Ethos QX 75 Nano-Micro RTF Quadcopter Jason M Mini Multirotors 269 Sep 26, 2014 07:27 AM
Sold Getting out sale.. Blade Nano CPX Brushless + Extras and 10 Brand New Batteries UGT10 Aircraft - Electric - Helis (FS/W) 1 Apr 08, 2013 02:25 AM
Brand new Great Planes F86 Sabre EDF mini jet for Blade Nano Cpx or Tricopter aviator422 Non R/C Items (FS/W) 0 Mar 29, 2013 02:37 AM
