Old Apr 29, 2013, 11:19 AM
bebeep89 is offline
Find More Posts by bebeep89
What is a controlled landing?
bebeep89's Avatar
United States, WI, Sun Prairie
Joined Feb 2013
Help!
Tamiya Wild Dagger Speed Controller
Greetings,
I have a Tamiya Wild Dagger that I got back out of storage over the weekend. My question is about the speed controller in it. It currently has the OEM MSC in it and I only have 2 speeds. Off and Wide open. I cleaned the contacts on the MSC but that didn't help. I can get it to go full throttle forward and reverse but nothing in between. I was considering an ESC for it but it's an older truck and I am not sure what it compatible with it since it has dual motors. That and I am not 100% sure if that is my entire problem . Any help would be awesome.
Thanks in advance.
bebeep89 is offline Find More Posts by bebeep89
Old Apr 29, 2013, 09:25 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Is the resistor block intact and connected to the MSC still? It uses the resistor to limit voltage for the lower speeds.
You can definitely get an ESC that'll work with dual brushed motors, especially if you're running the stock silver can motors.
wparsons is offline Find More Posts by wparsons
Old Apr 29, 2013, 09:58 PM
bebeep89 is offline
bebeep89's Avatar
Joined Feb 2013
As far as I can tell yes it is. I haven't disconnected anything and I was driving it around yesterday. It is all stock. Do I just look on ebay for a dual motor esc or should I try my local hobby shop?
Old Apr 30, 2013, 12:30 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You don't even need a dual motor one if you keep mild motors in it, just wire the motors in parallel to the ESC motor outputs. Just make sure you get a half decent ESC and not a really cheap one that would barely handle a single motor.
Old May 02, 2013, 09:17 PM
bebeep89 is offline
bebeep89's Avatar
Joined Feb 2013
Any suggestions?
For Sale 6x6x6 wild dagger bigdogrod Cars - Trucks and Parts (FS/W) 0 Mar 03, 2011 10:23 AM
Sold Tamiya Wild Dagger control Cars - Trucks and Parts (FS/W) 7 May 20, 2010 09:13 PM
ESC for Wild Dagger? mikez104 Electric Power Cars 3 Mar 16, 2005 12:39 AM
Question Tamiya Wild Dagger Zerosk8r14 Micro Cars 4 Jul 03, 2004 09:12 AM
Wild Dagger or Twin Detonator Seed Gear e_lm_70 Off-road Cars 0 May 11, 2004 07:12 AM
