Old Apr 29, 2012, 02:32 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
HBZ 4900 brick aftermarket
back about 6 months ago I asked, and I was given a few links
about a Hobbyzone champ dsm2 brick running around 20.00 at trainworld or wholetrains I think.
If any one has a lin vs the actual hobbyzone one. mine has bitten the dust finally un reparable.
thanks for all your help
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Apr 29, 2012, 05:03 PM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
You are thinking of the Spektrum brick that typically is included in the 3-channel Parkzone airplanes. Wholesaletrains.com is the outfit that sells it, but I think the way most of us get one of these bricks is to buy from that outfit a Champ fuselage that includes the brick and a motor with gearbox. Cost is $37.99 US. It's well worth the price, because the motor is pretty good, and you can build an airplane with that fuselage using some 2mm Depron foam.
Note that the brick is not an AR6400, so it doesn't have a port for ailerons, nor can you use it with a brushless ESC and motor.
Try http://www.wholesaletrains.com/Detail.asp?ID=200841116
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Apr 30, 2012, 04:26 AM
Joined Oct 2006
thank you,
No.
I believe I was directed to one as for a Mini Super cub $20.00
Understand the Best value is a Fuselage and electronics you get the whole kit vs just the electronic rx.
If I had to I can opt for the HK one.
thanks for the info
Old Apr 30, 2012, 12:24 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by fishycomics View Post
thank you,
No.
thanks for the info
The Mini Super Cub Bricks isn't DSM2 and neither are any of the HK bricks.
Saving money you won't be.
UNGN is offline Find More Posts by UNGN
Old Apr 30, 2012, 01:50 PM
Joined Oct 2006
ike I said I thought wrong Lol thanks but I wasdirected to a dsm2 brick though I know the mini is 72 or so mhz
Old Apr 30, 2012, 04:51 PM
I R Irv is online now
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
[QUOTE=UNGN;.[/QUOTE]
I knew you where "YODA"
I R Irv is online now Find More Posts by I R Irv
Sold Red Bick 70A ESC one with and one without BEC hemiblas Aircraft - Electric - Power Systems (FS/W) 3 Apr 23, 2012 08:10 PM
Discussion Hbz champ esc swap Chargedflyer Power Systems 3 Feb 06, 2012 05:54 PM
Discussion HBZ Champ brown out issues Deltaforce1 Micro Ready-to-Fly 28 Oct 27, 2011 08:51 PM
where can i buy the motor bick?? fung Motorcycles 1 Jul 22, 2004 10:42 PM
District 8 bick eeerrrrrr discussion... Hossfly AMA (Academy of Model Aeronautics) 13 Oct 11, 2003 05:36 AM
