Old Jan 07, 2003, 07:41 PM
hs748 is offline
Find More Posts by hs748
North America
Joined Sep 2002
Corona rx/gyro placement
Hi,
Almost done building the Corona!
I know there have been some problems with glitches using the LMH recommended postitions for the gyro and rx.
I was thinking of mounting the gyro at the rear of the crutch, above the tailboom (as Fred, Hoverup and others have done).
I then saw some people were leaving the gyro up front on the left side of the crutch, and moving the receiver to the right rear side of the crutch, just above the rear-end of the servos. How has this worked?
Also, should i mount the antenna as shown in the manual, or use an alternate location?
Thanx,
Jarrett
hs748 is offline Find More Posts by hs748
Old Jan 07, 2003, 09:16 PM
eekflyer is offline
Find More Posts by eekflyer
Spark antenna on my Tx !
eekflyer's Avatar
USA, PA, Pittsburgh
Joined Mar 1999
Hi Jarrett,
I mounted a Heli-max (soon to be Futaba GY240) on the right rear above the boom, the radio on the left front, and the battery underneath using Voyager gear. The ESC (a larger Futaba model) is mounted on the right side, just opposite the AF motor in front of the main shaft. The deans antenna scares me, so I mounted an antenna tube to the gear and threaded the antenna though.
So far so good. This setup seems to be fairly in line with what has been shown to work according to others on the board.
Best of luck,
EEK
eekflyer is offline Find More Posts by eekflyer
Old Jan 08, 2003, 02:04 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
If you haven't mounted the Gyro yet, it fits great below the TR servo on the crutch. No new mount needed.
I moved my antenna to the rear also, so it is clear of ALL the electronics.
Keep the ESC close to the motor, and keep the RX as far from the motor/ESC/gyro as possible.
Fred Bronk is offline Find More Posts by Fred Bronk
Corona Gyro placement question la-flyer Electric Heli Talk 14 Aug 07, 2003 05:45 PM
Buying a Corona,... what Gyro? Pongo Electric Heli Talk 13 Jul 15, 2002 03:20 AM
Corona Rx & Gyro Placement Mark E Electric Heli Talk 4 Jul 12, 2002 01:26 PM
Gyro Placement in Voyager jimmyG Electric Heli Talk 1 Dec 29, 2001 10:15 AM
Gyro Placement Jon Andrews Electric Heli Talk 3 Dec 23, 2001 10:16 AM
