Old Jan 18, 2015, 08:50 AM
Romushok is offline
Find More Posts by Romushok
Romushok's Avatar
Montichiari, Nothern Italy
Joined Apr 2007
Mini-HowTo
Turnigy I-10 works with other radio system
Description:
Hi gang,
I want to share my experience here to finalize a transmitter for use with receivers of other systems. You will need:
- RF module system you want;
- 2 position switch;
- SMA antenna connector with pig-tail;
- step-up voltage regulator;
- a bit of wires;
- double-sided foam adhesive tape;
-patience.
The principle is simple - switch the power supply from one module to another. The transmitter body is very narrow, but one module can be set inside.
So, in order:
1. It is necessary to break the chain of power supply of the original RF module. I decided to unsolder it from the board and lift it on short legs - all pads, except 3.3V.
Description: Name: DSCF0999.jpg
Description:
2. The board has modulator output - PPM pad from which to take the signal for our add-on module. Solder wires on the board to the ground, PPM, 3.3V and Vin on module.
Description: Name: DSCF1003.jpg
Description:
3. Normally all RF modules are powered from 5V, so we need to step-up regulator. How to connect everything together - shown in the diagram.
Description: Name: DSCF1019.jpg
Description:
Space inside the body is small, so it's best to use the mini switch.
4. Make a hole for the antenna and switch, place the module and step-up regulator on double sided tape inside of the case on the back.
Description:
5. Putting everything together and enjoy ...
An external antenna can be attached directly to the connector or through the L-shaped adapter.
Description: Name: DSCF1011.jpg
Description: Name: DSCF1013.jpg
Description: Name: DSCF1014.jpg
Description:
During operation encountered a problem - it is impossible to completely disconnect the original module. Thus or work only original module or both at the same time. This naturally faster battery drain. Pinout of original module present here, may be somebody can prompts how to completely eliminate its activity.
Description:
I hope it will be useful to someone.
Here is a short video
Romushok is offline Find More Posts by Romushok
Old Jan 18, 2015, 12:33 PM
dreamfalcon is offline
Find More Posts by dreamfalcon
Joined Jan 2015
the correct link
Turnigy I-10 works with other radio system (1 min 2 sec)
dreamfalcon is offline Find More Posts by dreamfalcon
Old Jan 18, 2015, 01:25 PM
miss5031 is offline
Find More Posts by miss5031
Joined Nov 2011
Very cool. Didn't think someone would be moding so quickly. Same concept as the Deviation fw upgrade for the Walkera Devo txs.
miss5031 is offline Find More Posts by miss5031
Old Jan 18, 2015, 02:01 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Didn't expected a 2015 radio still feature PPM... if this stream, supposedly 10 channels, can be called PPM
renatoa is offline Find More Posts by renatoa
Old Jan 18, 2015, 03:34 PM
Romushok is offline
Romushok's Avatar
Joined Apr 2007
Originally Posted by dreamfalcon View Post
the correct link
Thks, man
Old Jan 20, 2015, 01:29 PM
Outlaw_NL is offline
Find More Posts by Outlaw_NL
Joined Dec 2014
Nice mod! Will try that too!
Outlaw_NL is offline Find More Posts by Outlaw_NL
Old Feb 05, 2015, 07:29 PM
derek4610 is offline
Find More Posts by derek4610
Joined Dec 2009
Romushok, thanks for sharing. One problem I see, you are still feeding the i10 module with 3.3v when enabling the Corona module. Be carefull as you are powering the i10 RF module from one of the i/o or control lines from the micro. You can damage the micro if the RF module pulls to much current when you disable the 3.3v going to the i10 module. You can correct this problem with a tri-state or possibly a couple of FETs. Also an RF switch (part# AS215-92LF, under 1 dollar) will allow you to use one antenna for both RF modules and is simple to hook up. I am in the process of converting a i10 to Hitec. I was not going to keep the i10 module in the radio but now I'm thinking about it. Ether way I will post my results and designs when completed. Thanks for sharing and great first hack on the i10. Never stop hacking, it's now part of the hobby.
Derek
derek4610 is offline Find More Posts by derek4610
Old Feb 06, 2015, 10:00 AM
Romushok is offline
Romushok's Avatar
Joined Apr 2007
Thanks Derek,
I'm waiting for diagrams, it's really interesting. If you can edit your post, please cancel reposting for save a space.
Old Feb 19, 2015, 10:13 AM
Romushok is offline
Romushok's Avatar
Joined Apr 2007
A little update. I've replace old Corona module to Corona V2 DSSS and arrange it so that now I can access to bind button and LED.
Removed all unnecessary from module to reduce the thikness.
Description:
Fixed by hot glue, though I hate it...
Description:
Seems not too bad
Description: Name: DSCF1043.jpg
Description:
Old Apr 18, 2015, 01:16 AM
Jacksmobile is online now
Find More Posts by Jacksmobile
United States, FL, Port St Lucie
Joined Aug 2004
Looks like the original module stays lit and operational were you not able to disconnect the power to the original module as the wiring indicates ? Feedback it's been months now would you do this mod now knowing what you know anyone chime in please we need info
Jacksmobile is online now Find More Posts by Jacksmobile
Sold Hitec Spectra 2.4J GHz TX module (works with Taranis and any other JR style radio) MarLi Aircraft - General - Radio Equipment (FS/W) 0 Jan 10, 2015 04:41 AM
Sold Hitec Spectra 2.4J GHz TX module (works with Taranis and any other JR style radio) MarLi Aircraft - General - Radio Equipment (FS/W) 0 Dec 21, 2014 08:41 AM
Discussion 2.4 Turnigy TX/RX systems & Other TX/RX systems as well rab23us HobbyKing 8 Apr 19, 2012 03:02 PM
Question antenna tracking system other than eagletree, that works with other brands of OSD? TheSelf FPV Talk 32 Mar 08, 2012 09:53 AM
Discussion are all CX1 parts (other than the radio system) interchangable with CX2 parts? bmor Coaxial Helicopters 14 Feb 03, 2007 11:23 AM
