Old Nov 25, 2014, 12:04 PM
stacker is offline
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Build Log
B1b bomber (4x70mm)
This is my first thread in a long time and I decided to put it in the giant forum.
Seven years back I designed and built a 51mm powered stand off scale B1b that flew pretty good but lacked retracts. Took seven years to re-visit the plane but it's back and a 50% larger Bone. This will be my first fiberglass build and will used the plug / packing tape method.
Specs: Span 86"
Power 4X70mm fans with custom wound motors.
Battery 6s 4000 x 2
Some progress has already been made but I will back track to show progress.
Cheers -- Stacker
stacker is offline Find More Posts by stacker
Old Nov 25, 2014, 12:07 PM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Fuse plug beginnings --
Old Nov 25, 2014, 12:08 PM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Fuse rough shaped --
Old Nov 25, 2014, 12:24 PM
Katniss is offline
Find More Posts by Katniss
Katniss's Avatar
United States, CO, Fort Collins
Joined Nov 2013
impressive
Katniss is offline Find More Posts by Katniss
Old Nov 25, 2014, 12:56 PM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Thanks Katniss,
This will be a challenge for my first fiberglass build. Good thing I picked a easy subject ;-)
Power system is all built up and tested. I went with 10 blade fans as I'd tested these in a modified Dynam ME262 with good results. 262 flew well on 4s using cheap 2300kv outrunners at around 600 watts each and plane weight around 6 pounds. B1 power will be around 750-800 watts per fan on 6s.
Take care -- Stacker
Old Nov 25, 2014, 03:19 PM
jhspring is offline
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Great to see you on the threads again, Stack. If I could impose, please put a lot of pics of the fuse/glass process up. I want to try that on an upcoming build. You going to swing the wings?
Watching with interest,
Jeff
jhspring is offline Find More Posts by jhspring
Old Nov 25, 2014, 03:41 PM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Jeff,
Been a long time since I did a build thread. I got burned out on foam and have been thinking of switching to glass on larger builds. I'll post catch up pictures and show how I'm trying to do it.
Will swing the wings for sure.
Here is a picture of nacelle plug. I decided to try the nacelle plug first before attacking the fuse with glass. Plug is made up of tree sections of 2" pink foam for top and bottom. Sections are rough cut, glued back together and then contoured to shape. After rough shaping I apply Spackle and final sand. Important to keep ref. center lines on plug as they will be used to mark the onto the glass.
--Stacker
Old Nov 25, 2014, 04:05 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Glad to see you got the thread started Dave. We'll be watching.
J
J Morgan is offline Find More Posts by J Morgan
Old Nov 26, 2014, 08:11 AM
raipe is online now
Find More Posts by raipe
raipe's Avatar
Finland
Joined Oct 2008
Subbed!
raipe is online now Find More Posts by raipe
Old Nov 26, 2014, 09:40 AM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
More fuse plug finishing photos.
--Stacker
Old Nov 26, 2014, 10:34 AM
turbonut is online now
Find More Posts by turbonut
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Super cool...Nice to see you back at it Stacker. I always enjoy your builds.
turbonut is online now Find More Posts by turbonut
Old Nov 26, 2014, 11:16 AM
corsair nut is online now
Find More Posts by corsair nut
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
nice to see you back in action stack!!!!
I might have to come check it out, we'll be up in your area for christmas
corsair nut is online now Find More Posts by corsair nut
Old Nov 26, 2014, 11:49 AM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Thanks guys,
Been away from scratch builds for some. I've just been lurking watching Morgan's builds. I was up in the air on the B1, bounced back and forth between it or a similar sized B-58. I actually started the B-58 and had the nacelle plug ready and the landing gear built up before switching to the B1.
CN,
Drop me a PM if you come into town. Sorry, no flying field anymore in Salt Lake.
Old Nov 26, 2014, 05:39 PM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Fuse plug is about ready in this shot. Matches photoduggery pretty close.
I'll lay up the nacelles first for practice, then the fuse.
--Stacker
Old Nov 26, 2014, 10:47 PM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Nacelle shell lower half.
B1B Lancer anyone? Paul Susbauer Electric Ducted Fan Jet Talk 41 Dec 07, 2007 09:36 PM
Discussion Looking for B1b bomber section views and 3 view stacker Pusher Prop Jet Models 8 Nov 30, 2007 10:18 PM
B1B Cross Sections Paul Susbauer Scale Kit/Scratch Built 8 Mar 16, 2005 02:07 PM
B1B inspired jet design Ado Electric Ducted Fan Jet Talk 5 Aug 02, 2004 01:48 PM
WTB sept 1984 Aviation Week & Space Technology that had the B1B on cover hulbear Aircraft - Electric - Airplanes (FS/W) 0 Jan 22, 2003 08:13 AM
