Old Aug 03, 2014, 10:31 AM
2400RDR is offline
Find More Posts by 2400RDR
Out of helis, sanity returning
Tallahassee, FL
Joined Feb 2009
Question
TopSky replacement wing
Anyone know where I can get a replacement wing for my TopSky DLG? I've posted to the classifieds, but nothing came up. Maybe there is somewhere that sells replacement parts? I hope....
2400RDR is offline Find More Posts by 2400RDR
Old Aug 03, 2014, 10:56 AM
Triggerhappy is online now
Find More Posts by Triggerhappy
Joined Apr 2009
There's been allot of talk lately about Top Sky retooling/regrouping/changing owners.....? Something's going on with'm.
I've got a T.Sky 2.0 (maybe 3, it has triailerons). Well, it HAD tri's, I epoxied them straight with the wing after a flutter indecent ripped the Kevlar hinge along with a couple bad spots in the aileron itself. Haven't repaired the aileron hinge yet, and don't know if I will. I may just get another Neo wing instead (it's a Neo fuse). If you're interested in repairing it, I'll probably sell it cheap.
Triggerhappy is online now Find More Posts by Triggerhappy
Old Aug 03, 2014, 11:04 AM
2400RDR is offline
Tallahassee, FL
Joined Feb 2009
That's and interesting idea, but I imagine that shipping a wing that's already glued together might be a task. But PM me, and I'll give you my email address. Then you can send me a photo or two so I can see what we're looking at in terms of repair.
Old Aug 03, 2014, 01:54 PM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
Now fortified with carbon
DLGjunkyard's Avatar
Canada, ON, Cambridge
Joined Apr 2010
http://www.rcgroups.com/forums/showthread.php?t=2214340
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Aug 03, 2014, 03:05 PM
2400RDR is offline
Tallahassee, FL
Joined Feb 2009
Originally Posted by DLGjunkyard View Post
Thanks- Ill check it out.
Old Aug 03, 2014, 03:22 PM
Joined Apr 2009
Sorry, had a birthday party to attend (nephew).
After seeing the D box wings link, I'd go that route if I were you.
I'm considering a set myself!
Old Aug 04, 2014, 02:09 PM
thistle2311 is offline
Find More Posts by thistle2311
Lots of Air Play
United States, CT, Coventry
Joined Dec 2008
Get yourself a Zone wing from one of the several builders out there and adapt it to your Topsky pod. You'll be pleasantly surprised. Higher launch and penetration, good float too! Been there, done that!
Dave in CT.
thistle2311 is offline Find More Posts by thistle2311
Old Aug 04, 2014, 03:48 PM
2400RDR is offline
Tallahassee, FL
Joined Feb 2009
Dave in CT.
Dave-
What's involved in adapting a wing? I'm very much a newb at this stuff, although I'm beginning to get the idea that it's quite possible to buy pods, booms, wings, tails and so forth separately and make a DLG.
Old Aug 04, 2014, 05:13 PM
bbbp is online now
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
You just have to join the wings and drill the mounting holes. One of those measure 6 times drill twice jobs.
Drill one hole first, the get the wing aligned and drill the second.
Depending on the mounting style of the fuse it may be possible to insert something in the existing second mounting hole to help mark the proper spot to drill.
Or you can drill oversize, and put a sleeve on the hold down screw / bolt then use a splooge mix to set it.
Lots of ideas on RCGroups, especially the build threads.
BP
bbbp is online now Find More Posts by bbbp
Discussion Topsky viper, Wing mounting issue 3d addict Hand Launch 15 May 30, 2014 04:14 PM
Sold TopSky 2.0 Wing SkipMillerModels Aircraft - Sailplanes (FS/W) 3 Mar 26, 2014 03:16 PM
Wanted Any wing to replace the one on my Topsky CapeThermalizer Aircraft - Sailplanes (FS/W) 2 Oct 06, 2013 03:23 PM
Wanted Need Mini TopSky wing wdwimbish Aircraft - Sailplanes (FS/W) 4 Oct 02, 2013 10:09 AM
Found DLG Wing to replace Topsky Wing Yablonsky Aircraft - Sailplanes (FS/W) 8 Feb 11, 2011 08:43 AM
