Old Apr 18, 2014, 01:21 PM
Gautier is offline
Find More Posts by Gautier
Joined Mar 2007
Hi, thank you for your quick answear....can you give me the page number to re found in manual where i can calibrate battery voltage ?
Good week end....
Gautier is offline Find More Posts by Gautier
Old Apr 18, 2014, 03:11 PM
Graupner USA is offline
Find More Posts by Graupner USA
Graupner USA's Avatar
United States, CA, San Diego
Joined Oct 2013
You are welcome!
Go here and follow the instructions.
Graupner USA is offline Find More Posts by Graupner USA
Site Sponsor
Old Apr 20, 2014, 01:33 AM
Gautier is offline
Joined Mar 2007
Thank you.....
but sorry i'm in europe and i can not open your website ( why !?)....
Have a nice day
Old Apr 28, 2014, 10:44 AM
orange11 is offline
Find More Posts by orange11
Germany, BY, Munich
Joined Nov 2012
Is there a reason why the US website http://www.openhobby.com cannot be accessed from Europe?
orange11 is offline Find More Posts by orange11
Old May 03, 2014, 02:12 AM
Gautier is offline
Joined Mar 2007
Flybarless receiver
Hello ,
i have a question : is there flybarless system in the hott receiver " GR-12 + 3XG + 3A + VARIO 2,4GHZ HOTT" ?
On the paper it seems to be like GR18 with 3xg+3a+vario ...with only 6 ch ....and few less money
Thanks for your answear....
Have a nice week end .
Old May 03, 2014, 06:44 AM
Chris Benndorf is offline
Find More Posts by Chris Benndorf
Deutschland, RP, Altleiningen
Joined Jul 2011
No, FBL is only available in GR-18+3xG and GR-24Pro
Chris
Chris Benndorf is offline Find More Posts by Chris Benndorf
Old May 03, 2014, 10:01 AM
Gautier is offline
Joined Mar 2007
Thank you.
Old May 04, 2014, 06:59 AM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by davidmc36 View Post
That just sounds like assigning a switch to a channel.
I was going through some programming last night and saw that when I want to assign a switch to something I can choose FX and FXi:
"Fixed switches FXI and FX
This type of switch turns a function, e.g. a timer, permanently
on (closed fixed switch) or off (open fixed
switch) or they can provide a fixed input signal for a
control function, e.g. FXI = +100% and FX = -100%.
For example, in flight phase programming, these fixed
switches can be used to switch a servo or speed
controller between two settings."
I couldn't think right off how one would use them.
I am still at a loss to understand just what the purpose of these are. Anybody have an explanation?
davidmc36 is offline Find More Posts by davidmc36
Old May 04, 2014, 06:12 PM
teamhairball is offline
Find More Posts by teamhairball
United States, NY, Albany
Joined Jan 2013
Voltage Module 2-4S, XH 33631
Originally Posted by Graupner USA View Post
I don't have one laying around here to test. Will get back to you next week.
It has been a few weeks. Were you able to get this module to work?
http://www.rcgroups.com/forums/showp...&postcount=234
If you still don't have one in stock to play with I would consider sending mine to you.
teamhairball is offline Find More Posts by teamhairball
Old May 11, 2014, 08:07 PM
xtraflyr is online now
Find More Posts by xtraflyr
xtraflyr's Avatar
Chester NJ
Joined Nov 2005
I was using my general flight module today for the first time. A couple of questions. A)the RX temp alarm went off telling me the RX was at 158deg F. What is the amount of heat can the ex take? It was sitting in the sun under a big clear canopy. Once I started flying the RX cooled off and no more warning.
(b) at idle the rpm was way off. The telemetry was telling me 3200 but my friends hand held tach was saying 1700 rpm. At full throttle it was only off by maybe 100rpm's. Maybe I just need to get it in a better spot? It's mounted in the motor box facing thru the cooling holein the cowl.
Frank
xtraflyr is online now Find More Posts by xtraflyr
Old May 11, 2014, 11:52 PM
kurodo is offline
Find More Posts by kurodo
kurodo's Avatar
Joined Jul 2011
Dear Graupner USA,
it is something strange on the Graupner official website concerning HOTT files versions numbers: if you look at the german language page some files version numbers are not the same compared to the English language page.
Examples:
MZ-12 : V1.054 vs V1.053
GR-12S: V3a57 vs V3a55
GR-12 : V3a67 vs V3a65
GR-16: V6a37 vs V6a35
GR-24: V3a78 vs V3a76
Some Brushless ESCS on the german page are at V1a41 vs V1a34 ...
Some other file versions match ???
Can you clarify ? Thanks in advance
kurodo is offline Find More Posts by kurodo
Old May 12, 2014, 12:19 AM
Joined Oct 2013
Frank, you will have to experiment a bit with the sensor location to get accurate readings. The RX can handle quite a bit but temperature can creep up very fast when the model sits under a direct sun without airflow.
Frank
Site Sponsor
Old May 12, 2014, 12:22 AM
Joined Oct 2013
We here in the US are not handling the German website. My recommendation is to use the firmware upgrade studio to automatically download and update the firmware. If you decide to update manually then your best bet is to get the firmware from the OH or German website.
Originally Posted by kurodo View Post
Dear Graupner USA,
Examples:
Site Sponsor
Old May 12, 2014, 12:44 AM
fiery is offline
Find More Posts by fiery
fiery's Avatar
Hervey Bay, Queensland, Australia
Joined Mar 2008
A couple of questions!
1. Do the Graupner/SJ Transmitters use lithium 'watch batteries' (2032 size typical) to keep memory alive?
2. Can I order stiffer stick tension springs for my MZ-24? If so, please provide a link to you on-line shop entry. Is the swap procedure straightforward for owners to carry out? I have changed springs on other transmitters.
fiery is offline Find More Posts by fiery
Old May 12, 2014, 01:20 PM
Smashtorrent is offline
Find More Posts by Smashtorrent
Smashtorrent's Avatar
United States, AZ, Mesa
Joined Oct 2011
HoTT General air module 2-6S Vario
Hi all,
Is there a trick to getting the General Air Module 2-6S Vario to work with a GR-12L Receiver? I'm connecting the Air Module to channel 5 on the receiver, but I'm not showing the air module telemetry on my MZ24.
Smashtorrent is offline Find More Posts by Smashtorrent
New Product Graupner's new HOTT 2.4GHz system. Julez Radios 3115 Apr 25, 2015 02:45 PM
For Sale NIB Graupner MX-20 Hott Radio, $500 OBO flyboy0413 Aircraft - General - Radio Equipment (FS/W) 1 Oct 24, 2013 06:10 AM
Discussion Graupner HoTT radios un-bricking renatoa Radios 15 Jul 21, 2013 07:22 PM
Sold NIB-Graupner HOTT 2.4 mx-12 with receiver $199 + S&H unclegeorge Aircraft - General - Radio Equipment (FS/W) 2 Mar 30, 2013 11:41 AM
Wanted Seriously would like to get a Graupner HOTT MX16 or MX20 radio. unfaix Aircraft - General - Radio Equipment (FS/W) 0 Nov 12, 2012 08:44 PM
