Old Jan 03, 2015, 11:11 PM
pilot_keeter is offline
Find More Posts by pilot_keeter
pilot_keeter's Avatar
United States, GA, Pooler
Joined Nov 2008
Thanks! Maybe, I'll go back through my throws and keep testing. I set up 3 rates for each surface and don't see much difference from my 50% low to 100% high rates
pilot_keeter is offline Find More Posts by pilot_keeter
Old Jan 03, 2015, 11:24 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Fort Worth
Joined Dec 2010
If you go back to post 220 from Brad, he mentioned wing rock. And some tips. I've found being easy on the sticks and using throttle helps. With the CPM I have the ailerons at 90% in the rates and I think 45 to 50% expo.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Feb 20, 2015, 03:42 AM
jasonille is offline
Find More Posts by jasonille
jasonille's Avatar
Germany, RP, KL
Joined Aug 2012
Alright orange ordered and I have a 2202 KV1620 here on my bench. So reading through this thread adding alittle weight wont hurt. So can I run a 450 battery with this and 9g servos or is that to much? I plan on running the 8x4 prop with the motor and yes it says 2 or 3s.Thanks
jasonille is offline Find More Posts by jasonille
Old Feb 20, 2015, 08:40 PM
Twisted Do Nut!
Fort Worth
Joined Dec 2010
While adding a bit of weight (few grams won't hurt) a few ounces would. That battery and servos really would do better on the bigger Pitts not the Mini. You'd be better off with the recommended size servos and batteries.
Old Feb 21, 2015, 02:52 PM
tuck is online now
Find More Posts by tuck
Rouge Field
tuck's Avatar
United States, CA, Citrus Heights
Joined Feb 2009
Agreed. Stock recommendations are the way to go. The plane is fast enough, rolls, pitches and yaws with extreme authority. Needing less throw then usual. Bigger gear will detour satisfaction.
tuck is online now Find More Posts by tuck
Old Feb 22, 2015, 12:17 PM
jasonille's Avatar
Germany, RP, KL
Joined Aug 2012
Thanks guys I guess I will have to invest in some 250mah batteries I just have many 450's laying around.
Old Feb 24, 2015, 06:52 AM
Helfox is offline
Find More Posts by Helfox
You're gonna GLUE!
Helfox's Avatar
Canada, QC
Joined Nov 2012
m 2 cents. I found very little difference with my rates as well. My CG was too far back. Put the CG a little more forward and the rock disappeared and rates were noticeable. I kept doing knife edges until the CG was bang on. Adjusted thrust angel and then played with my rates. Then I was finally happy with the plane.
Helfox is offline Find More Posts by Helfox
Old Feb 24, 2015, 09:16 PM
ROLLING CIRCLE is online now
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
Good news Helfox. Way to stick with it.
ROLLING CIRCLE is online now Find More Posts by ROLLING CIRCLE
Latest blog entry: Big Cement Pizza Guy - NEW
Old Feb 27, 2015, 03:30 PM
hot wings is offline
Find More Posts by hot wings
hot wings's Avatar
Joined Jul 2010
Hi,
just entered in the CPM club!
Arrived two days ago..
Great little bipe.
Still I have to choose which BL to buy and I'm watching this cheap and light 14gr
Turnigy Park250 Brushless Outrunner 2200kv
http://www.hobbyking.com/hobbyking/s...dproduct=14399
It seems ok..any comments about it?
John
hot wings is offline Find More Posts by hot wings
Old Feb 27, 2015, 04:15 PM
Twisted Do Nut!
Fort Worth
Joined Dec 2010
Can't comment on that motor. If I was getting a budget motor, I'd go for the sunnysky which is the same size and kv as the TH one. It can be found here.
Old Mar 01, 2015, 11:33 AM
jasonille's Avatar
Germany, RP, KL
Joined Aug 2012
Maiden done and wow what roll rates this little bi is a blast. I went with the 450 battery cause no 250s came in so I'm sure it will float even more than it already does which is awesome. This is my first bi but definitely wont be my last!!! I will be looking for some small 3s 250mah and this plane will be a hand full.
Old Mar 01, 2015, 12:08 PM
Eagle2Nitro is offline
Find More Posts by Eagle2Nitro
Unregistered User
Eagle2Nitro's Avatar
United States, LA, St Francisville
Joined Apr 2014
3S in the CP Mini????
Eagle2Nitro is offline Find More Posts by Eagle2Nitro
Latest blog entry: My Youtube Channel
Old Mar 01, 2015, 08:43 PM
baddley is offline
Find More Posts by baddley
United States, WV, Salem
Joined Mar 2006
Personally I think 3s will be a little too much for this Pitts. That being said I mainly fly mine in a small indoor gym and it is plenty fast enough
I just finished up my second CPM and a brand new CYM. Does anyone have a link to the parallel charging board for the 2s lipos with mini jst connectors at hobby king ?
Scott
baddley is offline Find More Posts by baddley
Old Mar 01, 2015, 09:29 PM
ufoDziner is online now
Find More Posts by ufoDziner
ufoDziner's Avatar
United States, CA, Anaheim
Joined Mar 2002
Just got mine done. I'm using a MicroDAN F3P motor with a Castle ESC and 300 Nano-Tech packs. It flies amazingly well. Couldn't be happier!
ufoDziner is online now Find More Posts by ufoDziner
Old Mar 02, 2015, 02:04 PM
hot wings's Avatar
Joined Jul 2010
Originally Posted by hot wings View Post
Hi,
Great little bipe.
John
I'm making some evaluations of various values of kv about Park250 BL Motor with e-calc..it's interesting..reducing Kv values (from 2200 to 2000 and to 1700) flight time is bigger with quite same thrust
http://www.hobbyking.com/hobbyking/s...er_2050kv.html
http://www.hobbyking.com/hobbyking/s...er_1680kv.html
Discussion Twisted Hobbys - Crack Yak Mini - Build Thread hercdriver7777 3D Foamies 2571 Apr 14, 2015 05:56 PM
Discussion Twisted Hobbys Crack Pitts 12 Build and Info Thread! cwojcik 3D Foamies 3345 Apr 03, 2015 11:28 PM
Discussion Twisted Hobbies Crack Pitts Mini - leaked picture thread jimbo320 3D Foamies 8 Jun 05, 2013 11:43 AM
Sold Twisted Hobbies Crack Pitts LPU Denver aerosheldon Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 08, 2013 05:51 PM
